My way sat nav
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
derbyshire1970
My way sat nav
Unread post by derbyshire1970 »
Can any body offer guidance on the on going faulty sat nav it has just brought up the following message
Read error source cannot be read. It posted this message just before it crashed back in December
Question
Could this mean it’s simply just the SD card itself that is faulty ?
x 6946
Re: My way sat nav
What function was being used when the message came up?
Sat NAV? If so, then it is possible the SD card containing the map data is on the way to expiring.
You could obtain another SD card that matches the specifications of your Map card and try to see if you can clone the contents onto the new card using a PC. There is the possibility that you may have issues reading the data on the PC too - which may confirm that your original media card is dying a death.
Replacing it with a new one for the maps you require may be the solution.
derbyshire1970
Re: My way sat nav
Good morning
The sat nav was on at the time.
Is the best place to buy a reliable upgrade to latest maps direct from the dealer. Or are they safe to buy off e bay
x 6946
Re: My way sat nav
You don’t purchase them from the dealer, they have a dedicated website here:
https://citroen.navigation.com/home/en_ ... enEMEA/GBP
Anything from eBay will be pirated, so I can’t comment on what you will get to be honest.
