Hi,
i have a problem with my citroen xsara phase 2 (2005). The car wont turn off normally. The only way to turn off the car is to put it on reverse gear. any idea??
Citroen Xsara not turning off !
- x 1056
Re: Citroen Xsara not turning off !
Need a bit more details like fuel type & engine size.
I’ll have a guess that its a 2.0 HDi diesel?
Have you checked fir any fault codes.
Any work been done on it recently?
When you stall the engine & take the key out do all the dash lights go out?
jbyt23
- Locked user account
Engine: 1.4 petrolwheeler wrote: 09 May 2020, 09:06 Need a bit more details like fuel type & engine size.
No fault codes
The car was "sleeping" for about 4 years.
Some electrical work was done to reconnect all lights..
- x 1459
It is likely that a wire has been connected to the wrong place, the wiring really needs to be re-checked.
There will (probably) either be a direct feed from the battery to the ignition circuit that should not be there, or the alternator has been connected wrongly, feeding its output to the ignition circuit instead of the battery.
