Xantia Tachometer
thing
Xantia Tachometer
Unread post by thing »
My tachometer has gone crazy. When I start the car, it works fine. But after about 5 minutes, it's needle drop to zero and does not want to move. If I stop the engine, and let it cool down. Then it works again... and again it works for a short while only.
What could be the possible cause of this?
x 1056
Unread post by wheeler »
its quite common for the flywheel RPM pick up sensor to cause this fault
AV
Unread post by AV »
[quote]
are there any fixes for this as mine has thsame fault, or is it a sensor replacement?
x 1056
if its a non HDi diesel then its most likely the sensor.if the sensor is faulty on a petrol or HDi then it probably wont start.you can check the resistance of the sensor,i think it should be about 380 ohms but i can't remember which pins you measure it on.
thing
Where is this sensor located? How can I access to it?
x 1056
depending on the gearbox it may be mounted at the top of the gearbox in the bellhousing pointing at the flywheel and have about 8 inches of black wire coming out of it with a 3 pin brown plug on it.or nearer the front of the gearbox with the plug straight into it.just a single bolt holds it in.
