Part number needed please
- My Cars: 2010 C4 grand Picasso 1.6 hdi
2008 Renault grand scenic 1.9d - x 3
Re: Part number needed please
To be perfectly honest I’m not all that sure myself. I keep getting numerous faults including gearbox fault , parking brake fault, EGR p0405 p1162 among others. The p1162 seems to have stopped now but the others keep coming back whenever I clear them. I read somewhere that this can be caused by a faulty fuse box somewhere near the battery or a broken wire around the rear of the battery, I’ve looked at the wires but can’t see anything obvious.
- KennyW
- My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate - x 132
Have you checked your battery is 100% as this causes some nightmare problems.
Kenny
Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
Not checked battery, but then I haven’t noticed any problems starting etc. I’ll get it checked ASAP.
Tested battery with a multimeter and I’m getting 12.7 with engine off and 14.37 with engine running.
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
What happens when you add some load to the battery ie lights etc. Voltage should drop a little but not any less than 12v.
Also worth given the engine a rev with load on to see what Voltage is. This should increase voltage again with lights etc on.
But it would appear your battery is looking good.
Kenny
Kenny
Yeah that’s what I thought, so if the battery is ok....... what else could it be ?
