Hi all just had a look at n reg xantia 19 turbo diesel and the suspension on the rear is perminatly high this is the only thing wrong with the car other than that its a nice car its in better condition than mine also newer and turbo diesel is just what i want. now what the guy who,s selling it told me was that after leaving the car for sometime the rear suspension goes right down then on restarting the car it goes stright to the top setting now im thinking its a height corrector problem eathier the plastic connector is broken or the valve itself has seized now im thinking of buying this car as its at the right price. so i can fix it advice please guys.
pete..................
xantia 19td suspension
- x 1457
druist
[email protected]
update
well ive just had another look at this car and all is not as bad as it first seemed the suspension was down and i fiddled about with the height lever in the car the suspension came up ok then i set it on the second setting let it do its business then set it to normal then the seemed to sit level ok now im thinking its just lack of lubrication on the corrector meaning just a sticky valve what do you think guys.
pete........................
