Coolant and Gear oil
Steve Walsh
- x 518
Re: Coolant and Gear oil
Not yet Paul, I am hoping to find out this afternoon,
- x 5674
Just Finn-ish then.
ksanturion10
- x 19
I can count (Steve Walsh wrote: 20 Apr 2020, 14:23 Confused on the ''does it have cooling fins'' for the correct amount to put in, Mine only has fins on the bottom as per the pic
...in a perfect World - maybeSteve Walsh wrote: 20 Apr 2020, 14:23 Oil that came out was very dirty, and metal sludge on the magnet, I don't know how Citroen can say filled for life...
BR
Martin
Only himself the stupid makes wrong, many are being confused by the clever
Steve Walsh
- x 518
Mornin all
Does anyone have pictures of old style and new style ML6C, Mine only has the cooling fins on the bottom and I am unsure how much oil to put in...
Ta
Ta
- x 6946
Steve, yours should be with fins so refer to the guide in my procedure on the previous page:
With Fins:Quantity of oil to fill after draining
Gearbox casing with fins: 1.9 Litres
Gearbox casing without fins 2.6 Litres
Quantity of oil to fill after an overhaul
Gearbox casing with fins: 2.2 Litres
Gearbox casing without fins 2.9 Litres
Steve Walsh
- x 518
Thanks Marc
It was just the fact it only had fins on the bottom, I have refilled with 1.9 litres of Total 75w80 GL4.
Coolant next, Expecting a delivery of Glysantin Coolant in next few days, then I will drain flush and refill.
Thanks for all the info
Steve
Steve
- x 1941
Nobody has come up with a photograph of gearbox without fins yet. Must admit I'm curious what the difference is.
Steve Walsh
- x 518
I have searched the web but can't find a pic of an earlier version.
When I drained the dirty oil out I recovered 1.55 Litres in a container and I don't think there could have been more than half a litre on my workshop floor, I had a half pipe under the drain plug but the speed it came out overwhelmed it. But glad I have changed it...
Car is still in my workshop and I am trying to figure out the best way to drain all the coolant out, flush it and ensure it is completely empty before I refill it.
But Its raining and I have nothing better to do..
- x 6946
It is my understanding that apart from the obvious effect of natural cooling, they are always looking for ways to make the cars lighter to meet stricter emissions and Euro standards. Fins on a gearbox can also be used to reinforce the structure - rather than making the gearbox casing thicker, so that can save some weight.
As an example, the ninth letter or digit in your VIN will tell you the type of gearbox you have and its specific Euro standard / Emission level. In the case of the C5 family there are 13 gearbox designations. There is a 6 speed manual gearbox that is Euro 3 certified and another 6 speed manual that is Euro 4 certified and another that is Euro 5 certified. Just a few examples, so making a few tweaks / design changes make a big difference to certification.
- x 3565
Having just done the cambelt and water pump on mine this weekend, I can tell you a surprising amount of coolant sits in the water pump once you've pulled the bottom rad hose off. There'd be no practical way of removing that water other than removing the water pump. The only other option would be heavy dilution of what's in there, but if you - like me - prefer to refill with distilled water (as per spec), then diluting with tap water will be a tiny bit counter-productive.
Steve Walsh
- x 518
I figured it wouldn't all come out of the hose, I have managed to find the Cylinder block drain and I am going to measure how much I drain out to see if I get it all,
I am not draining it until my new coolant arrives, just in case I need it .
Steve
Steve
- x 1746
Agree, best to avoid any tap water remaining in the system, as well as the remains of a different variety of coolant, and to do any final flushing with distilled/de-ionised water. All subsequent topping up should be done with exactly the same coolant.
Steve Walsh
- x 518
I have demineralized water to mix with the Glysantin concentrate coolant I have on order, I will be flushing with an hose, ( ours contains very little contaminants ). Inside our kettle is still clean and its about 4 years old. Then I am going to blow the remains out with compressed air.
Steve
Steve
ksanturion10
- x 19
...details
