Citroen DS5 2013
Hi,
I have been trying to source a replacement trim for the front driver's side door (vertical plastic strip by window) to replace a broken one, however, I have been unsuccessful in my search. Please, is there anyone on this forum who could guide me in the right direction in locating a replacement. Thanking you in advance.
Citroen DS5 B Pillar external trim
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5722
Re: Citroen DS5 B Pillar external trim
Hi
The trim parts are generally available - but it is unlikely you'll get these alone at a breakers and almost certainly not on the aftermarket.
You can source these from a Citroen dealer. If you want the info directly, I'll need to look up your vehicle data - then I'll be able to put a diagram for you to identify the part, then I can provide you with a part number and a current price. As we are now charged for this info , we do ask for a small Forum donation to help cover our costs - see the info below which goes into detail:
A response to your question will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
Donate Further Information |
- (Donor 2017)
- My Cars: Citroen C5 2.0 Hdi 2003
- x 39
Or you can find your own part number using http://www.catcar.info/citroen/?lang=en and base your search on that part number.
Potentially part number 96874980 XK (left-hand) or 96874450 XK (right-hand), if part 20 below is the part you need.
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
.... which is not precise, as even with the VIN, all the options are listed, and not the parts specific to the options fitted to the vehicle....
- (Donor 2017)
- x 39
Just noticed you said front driver's door: Part number is 96874014 XK - part 20 below.
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
- (Donor 2017)
- x 39
Can be gotten from https://www.online-teile.com/citroen-er ... anguage=en if you can bring yourself to pay that much for a bit of plastic. Probably either that or keep an eye on ebay for a few months.
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
Thanks all for your assistance, I never expected that it would be so difficult to source this part. Thanks for the advice.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I've responded to your PM on this.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
If you follow a search through - you will see it is a 'Demo' and does not search by VIN specifically, instead it offers all the variants of parts for every trim level and colour where appropriate. Nor will it provide data without you signing up and paying.
