Hi.
I’m new here.
I have Lexia 3 and purchased it two years ago.
Last used it two years ago. Loaded it tonight as wanted to do an ABS bleed on a 2007 Citroen C4 1.6 HDI VTR+. Having last used it a while ago I forgot that you mustn’t load Diagbox with an internet connection. I had several messages asking me to input my login details.
Very reduced functionality now. Will only let me do a global test for injection, BSI and ECU and let me read and refresh codes on ECU. Test by function to start diagnostics, driving aids, road holding ABS etc gets me to searching vehicle configuration and then nothing comes up. The version it is running is 7.57 on 32 bit Windows 7 Professional and by this point the version number top right is greyed out and not coloured green.
Any ideas what might have gone wrong? Has the VCI been bricked? I do still get the blue light on my version C VCI.
Lexia 3 / Diagbox Citroen C4 1.6 HDI
Markta
Re: Lexia 3 / Diagbox Citroen C4 1.6 HDI
So can anyone advise whether an uninstall/ install usually works.
Is this necessary or can the accidental connection to internet be fixed without this? If so, how do I go about it.
Any assistance greatly appreciated.
OnlinePaul-R
- x 1955
When you did your original installation, did you make a back-up copy of APPDIAG.SYS from C:\AWRoot\bin\fi?
If you did I suggest you copy it back over the original, probably damaged, file in C:\AWRoot\bin\fi.
Markta
Yep, APPDIAG.SYS has a back up copy on my desktop from C:\AWRoot\bin\fiPaul-R wrote: 12 Apr 2020, 18:00 When you did your original installation, did you make a back-up copy of APPDIAG.SYS from C:\AWRoot\bin\fi?
When you say copy it over, do you mean right click APPDIAG.SYS and copy then paste it on to C:\AWRoot\bin\fi?
Many thanks
- x 6950
Anytime you are asked for a password and login - usually on performing a certain function, if you decline it will deactivate.
Just Exit the application, restart the laptop then copy the backup you made of the file ^ above ^ (assuming you made a backup when you first installed it). If you didn't make a copy of this file, then I'm afraid it's a total uninstall, registry and file clean up and reinstall again. The licence file is unique to each installation so no good asking for one from elsewhere (just in case you were contemplating any alternatives).
Markta
Thanks Marc, I definately did back that file up at time of installation, so I have the following:-GiveMeABreak wrote: 12 Apr 2020, 20:13 Anytime you are asked for a password and login - usually on performing a certain function, if you decline it will deactivate.
The back up file is saved to my desktop so OK to send a copy of that to the folder AWRoot?
Cheers!
Markta
Right, so I deleted the original APPDIAG.SYS file from the folder above, then copied the desktop backup version and pasted it into the folder to replace the deleted one.
Assume this should now work?
Will have a go tomorrow and ensure that I am offline (internet).
In the meantime, if this isn't correct, please let me know.
- x 6950
Yes, that should be it. Make sure your wireless network adapter card is switched ON, but make sure you disconnect from any of your WiFi Router's network connections. Disconnect and make sure that 'Automatically Connect' is switched off so id doesn't automatically log you onto your WiFi network again. The WiFi adaptor card itself needs to be on as the MAC code of the adaptor is used as part of the encrypted licence code.
Markta
No go, getting to this when entering VIN before I can get to diagnostics on 'test by function'...GiveMeABreak wrote: 12 Apr 2020, 21:49 Yes, that should be it. Make sure your wireless network adapter card is switched ON, but make sure you disconnect from any of your WiFi Router's network connections. Disconnect and make sure that 'Automatically Connect' is switched off so id doesn't automatically log you onto your WiFi network again. The WiFi adaptor card itself needs to be on as the MAC code of the adaptor is used as part of the encrypted licence code.
Does this mean a complete reinstall?
- x 6950
That looks like a communication problem - it should be detecting the VIN automatically. If it's not, then it's not communicating. Check your interface - is the green light on the VCI lit all the time?
Markta
Yep, recognising the VIN and asking if that is correct. Then gives me the choice between Diagbox and Lexia 3, chose the latter, then Lexia. Entered the RPO then green tick. Then long menu, chose Diagnosis, then Test by Function, then switch off ignition then on again, then driving aids, then road holding (ABS....). Then says please wait, search for vehicle configuration.
At that point, you get a green bar loading up then types of system to be diagnosed. At that point, you’re meant to get BSI, Instrument panel, injection and ABS. I get none loading up....
The green VCI light is on at all times...I’m beginning to think the option to bleed the ABS doesn’t exist on my software. I did check some other test by function including airbag ECU and it picked up the airbag ECU...
I did have the battery off a few days ago for a charge and recon...
Markta
So I’m wondering whether the car has to be off economy mode (on instrument panel) for it to work by ‘test by function’ and can the ABS bleed be done through the global test where it picks up all the ECUs and you can then select the ABS ECU from there? Also, when on the ‘test by function’, when Lexia is searching vehicle configuration, can this take more than five minutes for the ECUs on a diesel engine to appear ie. instrument panel, injection, BSI and ABS?
Thanks in advance!
Thanks in advance!
- x 6950
Are you actually getting a choice? This is unusual - as Diagbox will normally load up automatically for the appropriate car without a choice. The only choices it usually gives you is for earlier cars where you can select Lexia or 'Scantool' which is the basic OBD reader.
It should not take anywhere 5 minutes to read the ECUs on a C4 - so it is obviously having some trouble communicating somewhere along the line. Economy Mode shouldn't affect the testing - but to rule this out, start the engine and run the diagnostics again with the engine running.
If in fact you are given a choice of Diagbox - try selecting that instead.
moizeau
- x 423
I get the choice of Diagbox or Lexia 3 on my 2010 Citroen van. I have only chosen Lexia once, normally I use Diagbox because Lexia can sometimes freeze.
Pete
Markta
Thanks Pete, can you bleed the ABS on a Citroen using Diagbox? If so, what menus do you need to select?moizeau wrote: 13 Apr 2020, 17:40 I get the choice of Diagbox or Lexia 3 on my 2010 Citroen van. I have only chosen Lexia once, normally I use Diagbox because Lexia can sometimes freeze.
