RT3 sat nav - replacing the non nav version
Harlequin
- x 23
Hi all! In my madness i have decided to add the RT3 sat nav , replacing the small hump non nav radio.
So far so good - cut out the hump, removed the small screen, installed the mount and large screen, checked the radio work (and rewired the 3 small wires to the screen - that all works) and the nav even picked up satellites and the phone.
But - when coming to code it on lexia (the joyful beep) ran into a large block. The radio ecu is not detected and the telematics (once enabled in bsi and as present in the cu section) has a ? next to it. Not sure where to go from here?
2005 C5 exclusive.
2005 C5 exclusive.
- x 6946
Re: RT3 sat nav - replacing the non nav version
Hi Simon - I hate to rain on your parade, but there are 2 variations of the RT3, depending on the electrical architecture of the vehicle a CAN and a VAN version - neither are interchangeable, Each is designed to work on a specific architecture - that's also why there is a different firmware for each of these.
Is this the model you have fitted?
Harlequin
- x 23
Thank you Marc.
Mine is a m1 facelift and the nav system is also from a facelift - both are canbus i think
Harlequin
- x 23
Harlequin
- x 23
Bottom is an RD4 X3 N1 EU
top is an RT3 X3 N1 EU
- x 6946
Were having some issues with the images not displaying - can you attach them directly to the forum - as we host our own images in case of issues like this.
OnlinePaul-R
- x 1941
Both links are just black for me. Can you not upload your pictures directly to the forum's servers?
- x 6946
You’ve changed your vehicle then, as I posted the units for the MK I.
The later units in the MK II also had a CAN and VAN version too.
Harlequin
- x 23
sorry editing photos - my car is a 2005 mk1 facelift exclusive, the nav kit came from a 2007 mk 1 exclusive.
The nav kit all works, just not detected in Lexia .
Harlequin
- x 23
update - all sorted, needed to ignore 1 option and just carry on - vin coded and all working. Lexia still doesnt pick it up - but its all working. Very wierd.
Harlequin
- x 23
So, hmmm, had an issue of recent. Hangs starts on the RT3 - switches on for the Citroen logo then nothing. Doesn't do it all the time, just occiasionally.
Harlequin
- x 23
Hmmm i think mine has the wrong firmware - it says 8.31? Pretty sure its supposed to start with a 6.xx? Can it be reflashed?
- x 6946
Hi Simon 8.31? That is not a firmware for the RT3.... That firmware is for the RT4/5 system.
Versions for the RT3 will begin 5.* or 6.* depending on the CAN or VAN version fitted. Your C5 should be the CAN version and the latest available firmware is 6.63 as below. The unit can be bricked if the wrong firmware is applied.
RT3 2001 VAN 5.50
RT3 2002 VAN 5.5D (colour)
RT3 2003 CAN 6.60
RT3 2004 CAN 6.63 (colour)
RT3 2001 VAN 5.50
RT3 2003 CAN 6.60
Harlequin
- x 23
Hmmm i honestly am at a loss then - it would explain ALOT as it says software version 8.31 .... and its an RT3! It does start sometimes and works though (occasionally). Can the firmware be downgraded?
Harlequin
- x 23
Its an RT3EV - was told to look on the back of the unit at all the connections
