307 1.6 hdi dpf remove?
Slobo2712
Unread post by Slobo2712 »
Hi.Is there any tutorial step by step how to remove dpf filter on 307 1.6 hdi.I have tried but there is no space much,and youtube tutorials are not clearly..
x 1459
Re: 307 1.6 hdi dpf remove?
Unread post by xantia_v6 »
Are you removing the DPF to clean it?
Slobo2712
xantia_v6 wrote: 03 Apr 2020, 23:57 Are you removing the DPF to clean it?
Yes..I know how to remove just dpf without cat,but i have thought to clean both?
x 1996
Unread post by Stickyfinger »
Never DIY "clean" a Catalytic converter, you will destroy the coatings.
Slobo2712
Stickyfinger wrote: 04 Apr 2020, 08:29 Never DIY "clean" a Catalytic converter, you will destroy the coatings.
Tnx for answer,so to clean dpf is safe?Nothing to broke?
x 1996
Correct...just do not drop it :)
x 6945
But be careful, as the honeycomb structure is very delicate and can come loose....
Slobo2712
It isnt in best shape at all..
x 6945
That does look like its on its last legs. They are not as expensive as they were a few years ago and there are lots available now on the aftermarket.
Looking at that, I would replace it as it seems to be disintegrating. Maybe it has been damaged by a previous clean?
Slobo2712
Maybe at former owner.It has sense.I cant replace it now because every parts store is closed for days..
Slobo2712
GiveMeABreak wrote: 04 Apr 2020, 14:00 That does look like its on its last legs. They are not as expensive as they were a few years ago and there are lots available now on the aftermarket.
What do you think is it smart to try to remove cat and broke banjo bolt net?
x 6945
Looking at the condition, - any sort of dismantling may cause it to break apart, so I wouldn't risk it personally, but if you do, just be very careful.
Slobo2712
GiveMeABreak wrote: 04 Apr 2020, 19:08 Looking at the condition, - any sort of dismantling may cause it to break apart, so I wouldn't risk it personally, but if you do, just be very careful.
Tnx,do you think is it that useful to break out banjo net I mean is it worth of risk
