307 1.6 hdi dpf remove?
Slobo2712
Hi.Is there any tutorial step by step how to remove dpf filter on 307 1.6 hdi.I have tried but there is no space much,and youtube tutorials are not clearly..
- x 1460
Re: 307 1.6 hdi dpf remove?
Are you removing the DPF to clean it?
Slobo2712
Yes..I know how to remove just dpf without cat,but i have thought to clean both?
- x 2005
Never DIY "clean" a Catalytic converter, you will destroy the coatings.
Slobo2712
Tnx for answer,so to clean dpf is safe?Nothing to broke?Stickyfinger wrote: 04 Apr 2020, 08:29 Never DIY "clean" a Catalytic converter, you will destroy the coatings.
- x 2005
- x 6957
But be careful, as the honeycomb structure is very delicate and can come loose....
Slobo2712
It isnt in best shape at all..
- x 6957
That does look like its on its last legs. They are not as expensive as they were a few years ago and there are lots available now on the aftermarket.
Looking at that, I would replace it as it seems to be disintegrating. Maybe it has been damaged by a previous clean?
Slobo2712
Maybe at former owner.It has sense.I cant replace it now because every parts store is closed for days..
Slobo2712
What do you think is it smart to try to remove cat and broke banjo bolt net?GiveMeABreak wrote: 04 Apr 2020, 14:00 That does look like its on its last legs. They are not as expensive as they were a few years ago and there are lots available now on the aftermarket.
- x 6957
Looking at the condition, - any sort of dismantling may cause it to break apart, so I wouldn't risk it personally, but if you do, just be very careful.
Slobo2712
Tnx,do you think is it that useful to break out banjo net I mean is it worth of riskGiveMeABreak wrote: 04 Apr 2020, 19:08 Looking at the condition, - any sort of dismantling may cause it to break apart, so I wouldn't risk it personally, but if you do, just be very careful.
