C5 X7 thermostat replacement
osx
(Donor 2022)
x 15
Re: C5 X7 thermostat replacement
Unread post by osx »
Don't you think that it will need to be drained anyway?
Engine is the 2.0 HDi - where is the cabin heater matrix?
C5 X7 Exclusive 2.0 HDi Auto
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
I can only answer the 2nd part of your question.
Along with most manufacturers the first thing installed in a car is the heater matrix, the rest of the car is built around it, so imagine sitting in the car in the rear seats and have nothing in front of you apart from a mass of wires pipes. No dash, no steering wheel, nothing except wires and pipes.
That is where the heater matrix lives :twisted: :evil: :twisted:
admiral51
(Donor 2026)
x 391
If this helps its similar to what you need to except :(
help!
osx
(Donor 2022)
x 15
That's not an X7 :)
admiral51
(Donor 2026)
x 391
No but when you get to it on an X7 post the pics here :)
admiral51
(Donor 2026)
x 391
Assuming its a RHD X7 just where your left foot rests when its not using the clutch, about 8 inches to the left of it is where the matrix lives, i am happy to do an A level exam in nuclear fusion before i tackle a heater matrix replacement, and i am as tech brainy as a dead fish :rofl2:
osx
(Donor 2022)
x 15
Surely there are pipes that can be accessed from the engine bay.
osx
(Donor 2022)
x 15
There are two coolants for the X7 (going to give it a try as the level is way too low so it could be a slow leak from somewhere)
https://www.eurocarparts.com/p/evans-po ... -993778002
https://www.eurocarparts.com/p/evans-au ... -993778012
what is the difference?
osx
(Donor 2022)
x 15
Hmm
"If the engine to be converted is currently filled with a water-based coolant an important part of a good installation is using Evans Prep Fluid."
How can I check?
osx
(Donor 2022)
x 15
Seems risky to top up with another coolant so water it is. Battery top-up water compatible?
admiral51
(Donor 2026)
x 391
Assuming that the X7 has similar proper soundproofing as it was aimed as a competitor for the BMW 5 series ( check the indicator action ) then have a look at Sponge like to see how much liquid it can soak up before you notice :)
If it helps that pic is 10 years old from a Xantia but squeeze and squeeze and drip dry for a week but it still is damp to touch :rofl2:
x 1930
Aldi are currently selling (or were when I was last out two weeks ago) Prestone ready mixed coolant. This will mix with organic and non-organic type anti-freezes.
osx
(Donor 2022)
x 15
Removed the air from the circuit and all the coolant disappeared from the tank! Had to add almost 3lt but everything seems to be working now. Will keep an eye for any leaks.
x 1240
Unread post by Peter.N. »
Phew, relief :-D
x 1751
IIRC from reading the MSDS sheet for those Evans products, the 'waterless' coolant actually contains . . . water.
As such, it will almost certainly work quite well as a coolant, as the heat-removing properties of (de-mineralised) water are actually rather good. But 'waterless' ? #-o
