Changing front headlights, citroen xsara
Post Reply
nash3f
New User
My Cars: Citroen xsara
Post by nash3f »
I'm trying to change the headlights on my xsara 2001, apparently i need to remove the front bumper.
I will appreciate some directions on how to remove it safely I'm really trying but can't find where to remove it from
My Cars: 1996 XM 2.5TD Exclusive hatch RHD
and lots of Rovers before that: 1935 Ten, 1947 Sixteen, 1960 P5 3-litre, 1966 P6 2000, 1972 P6 2000TC, and 1975 P6B 3500S
x 1752
Re: Changing front headlights, citroen xsara
Post by white exec »
Hi, and welcome.
Do post your VIN, so we can be sure to get the vehicle build details correct.
My Cars:
x 717
Post by wheeler »
Im guessing this is a mk2?
You don't need to fully remove the bumper, you can just drop it down enough at the one side to access the lower bolt.
Rough instruction from memory, undo the torx screws above the front grille, undo the screws that hold the wheel arch liner to the bumper, there is also a screw that goes up the way that holds the bumper to the front wing. Theres a few 10mm bolts on the bottom of the that also hold the undertray (if fitted). The bumper is held in place on plastic clips, you can then pull the bumper forwards to unclip it, this can sometimes need quite a hefty tug to get it to unclip. Once its unclipped you can drop it down at one side to access the lower headlamp bolt.
JohnD
(Donor 2022)
My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1
x 72
Contact:
Post by JohnD »
My daughter used to have a 2002 Xsara and about 12 years ago I had to remove the headlamp. I'm pretty sure that besides having to remove the bumper, I also had to loosen off the cross member to reach the bottom fixing bolt on the lamp.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Post Reply
