Expert 1.9 Split pipe help please
Post Reply
simon68
My Cars: 2003 Peugeot Expert at present.
Previously owned several berlingo's, Dispatch, two C15's & a Talbot Express
Post by simon68 »
Would very much appreciate some help/advice on my diesel leaking problem. Was having a great time stealth camping in Scotland before I got a strong whiff of diesel and a small puddle appeared. I braved it and started my drive back. Managed 90 odd miles before she packed up and thankfully got home with Green Flag recovery. I've been out there this morning and found a metal pipe leading to the pump has totally split. I've enclosed a pic. Sorry for poor quality. Am i right in thinking this is an injector pipe? I am a novice mechanic but if it's just a case of changing a pipe i'd like to have a go myself. How easy is it to remove the MAF sensor? I can't see a clip on it.
simon68
Re: Expert 1.9 Split pipe help please
Post by simon68 »
Sorry just realised it's not a Maf it's part of the plastic inlet manifold. How is that removed please?
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5742
Post by GiveMeABreak »
First things first - put you VIN up so we know exactly what engine you have - we'll need t his for part info anyway.
simon68
Post by simon68 »
Hi there, thanks for your reply. The vin is VF3**************[VIN obfuscated, can be read by forum staff] 1.9d
simon68
Post by simon68 »
I've included a better photo. I've just managed to undo the nut.
doctle
My Cars: 2008 Laguna 1.5 DCi
x 235
Post by doctle »
Everything is attached using nuts bolts screws and clips shouldn't be too difficult to take apart
Oh buggle
simon68
Post by simon68 »
Thanks Doctle, Yep it's Access that i'm struggling with. Does the thing at the front of the inlet manifold that resembles an air flow meter come off separately?
doctle
x 235
Post by doctle »
Some screws could be spline or even security screws like a torx with a little pin in the middle
Oh buggle
simon68
Post by simon68 »
I think it's a throttle body. Can't see any screws/torx etc. Does anyone know if they are just a push fit into the inlet? Really don't want to force anything until I know. I've located torx screws on the inlet itself but don't have the tools to remove back ones...so little space. Would make it possible to do though if I can remove the 'throttle body' on it's own.
My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl
x 1003
Post by RichardW »
Can you take a photo further out, can't make you exactly where you are looking?
simon68
Post by simon68 »
Hi Richard, thanks for reply. I will take one in the morning. I now know from looking at parts on ebay it's the egr and i'm pretty sure it just pushes in.
My Cars: 1996 XM 2.5TD Exclusive hatch RHD
and lots of Rovers before that: 1935 Ten, 1947 Sixteen, 1960 P5 3-litre, 1966 P6 2000, 1972 P6 2000TC, and 1975 P6B 3500S
x 1752
Post by white exec »
Better photos needed, then we should be able to post the relevant parts diagram.
doctle
x 235
Post by doctle »
EGR valves tend to be better secured than push in fittings.
Oh buggle
simon68
Post by simon68 »
That's what I thought but just found a photo online of the same one and it is indeed just a push fit.
doctle
x 235
Post by doctle »
Thanks thats news to me.
Oh buggle
Post Reply
