2.1Turdo 12v Shedroen Estate has arrived
x 1999
Unread post by Stickyfinger »
Some work to do.....
CLEAN the bloody thing !
Wet Boot and passenger foot-wells
Rust eating the rear arch
Seat foam/leather (drivers side)
Some crusty pipes under the rear, some have been replaced (brakes)
Oil leak at the back of the intake manifold
Alternator needs fixing (no charge)
Interior fan not working
No Radio Code
x 1999
Re: 2.1Trudo 12v Shedroen Estate has arrived
I wonder what is under the silver foil, nothing showing from under the car ?
citroenguy
(Donor 2021)
x 76
Re: 2.1Turdo 12v Shedroen Estate has arrived
Unread post by citroenguy »
This reminded me that i have some linky links for Xantia radio codes, since i also had a 2.1 TD for a short while..
https://www.radio-code.co.uk/citroen-radio-codes.html
viewtopic.php?t=13039
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
x 1485
The foil is just a heat shield over the rear silencer.
x 1751
Looking like a good find, Alasdair.
Inside pretty much the same colour (alcantara grey) as our XM here.
That radio code site should provide your code - have used it myself.
Would have thought any heat shielding would be under the boot floor...???
At least no shortage of circuit diagrams..... \:D/
x 1485
I can't remember if there is a heat shield underneath as well, but I can't see any other purpose for the foil!
The leak into the rear will be the inner membrane on the boot door coming away. Really you need to remove the liner and then the membrane then re-stick it with something super sticky - there is a thread about it somewhere which recommended some double sided foam type tape from 3M (for caravans IIRC....!)
It's unusual for the wing edge to go rusty, and not the door shut....!
x 1999
Ta for the radio links.....I will look at that..
I have inspected the rear wing a little more......there is zero rust damage to any of the inner wing or wheel arch panels...just the "dropped edge" of the outer wing...very strange as I expected the standard corrosion area that involves all three forms.
Boot plastic seal, the very first thin Jim said to me yesterday :)....my oh my the carpet is wet so I am glad I have removed it.
x 3304
Is that CitroJim you are talking about?
x 1999
Yep
x 1999
Rear seats removed, rear carpet has foam.....will release the rear screws from the seats and extract it for drying.....and I have NOT found any £1 coins yet which is very annoying !
x 1999
Gave up.....rear carpet out, dehumidifier in to get all the moisture out.
x 1999
Yep.....that was the cause....you can see the dirty stains and some fine soil debris on the bottom of the insulation and door card.
The plastic is rippled from being stretched during a previous removal. The is evidence of it being reapplied 2 or 3 times, sticky tape, some silicon and some black mastic residue covered the boot and the plastic.
x 1999
Washed it.....you can only put up with green moss for so long !
x 1485
The plastic membrane just ripples all by itself, which is what causes it to fail in the first place. I wonder if it might be better stuck on, then a bar screwed on over the top to hold it down.
x 1751
To straighten the edge, there's also some black plastic U-shaped binding strip (as used to slide-bind up to about 3mm of papers). which is good at remaining straight. Stationers sell it in A4 lengths, and some hardware depots have it in 1m lengths.
