(This is a referance vehicle stand. They can't adjust the height with theirs.)
What Should I Do When Remove 4 wheels ? C5 X7
sword1st
Hi. I will paint my wheels. They will lift the car with car jack and put it on vehicle stand. Their vehicle stands doesn't have height adjustment. If i rise the car to the top point height sensor will triggered when it's on vehicle stand. Should i remove the battery and act like conventional suspension ? I don't wanna let them do anything they want. I will guide them with the info i take here. Thanks!
- x 6956
Re: What Should I Do When Remove 4 wheels ? C5 X7
Read this - it explains the dangers of a burst tank when lifting the car where the wheels will be hanging unsupported:
viewtopic.php?t=62058
There is also a link to some warning labels - but in English.
sword1st
Thanks! I shouldn't remove the battery either i guess.
- x 6956
Any time you are going to disconnect the battery or remove it - follow this procedure to avoid any electrical problems:
BSI Reset / Battery Disconnect / Reconnect Procedure
