Hello all,
I must replace fog light bulb on my C4GP 2014. The problem is how to get it out. I understand that the plastic cover must go first to be able to access the bulb. Question is how to remove that plastic cover. I don't want to use force alone. I believe that there are some clips that hold parts in one piece. Can't see any obvious places where to use screwdriver or some other flat tool. Maybe someone did this procedure in the past?
C4GP fog light
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Re: C4GP fog light
Use some trim removal tools (with flat plastic edges) to remove the areas shown at 'a' by inserting the flat tool and levering down to unclip the tabs. Do the top or bottom first and lever a little at a time as you go along - this should make it easier.
Then undo the 2 bolts:
Then turn the assembly a quarter of a turn in the direction of the arrow:
Note: The bulb does not detach from the plastic holder - replace the whole thing:
- My Cars: 2014 Citroen C4 Grand Picasso
- x 3
Re: C4GP fog light
Thank you. You saved a lot of time!
- x 3
Re: C4GP fog light
Even wiht a tools for trim removal I am unable to remove covers.....I don't wan't to break anything. Even to insert a tool between bumper and cover is a task...
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 315
Re: C4GP fog light
Would a feeler gauge slide in?
Pete
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: C4GP fog light
Just push a plastic flat bladed tool in the locations arrowed so you can lever either the top of the bottom side off first, then one of the sides and the rest should be easy.
- x 3
Re: C4GP fog light
Thank you all guys. Just finished. Still managed to break one clip... In my opinion this cover removal could be designed a bit easier.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
