Peugeot 3008 Hybrid RT6 not booting.
- x 6945
Re: Peugeot 3008 Hybrid RT6 not booting.
If that doesn't work - then try and put it in bootloader mode. Extract the RT6 from the fascia, leave it connected and carefully look on the underside of the RT6 unit. There will be 2 white switches. Ensue the Firmware CD is loaded into the RT6, then hold down the 2 switches (engine running), then this should trigger the CD reading and reinstalling of the boot code onto the system.
AlamSAsif
It's around 40 minutes. Still nothing on display. It reboot couple of times in between or pause couple of times and start spinning cd again. Do I need to wait more or try the boot loader mode?
AlamSAsif
I cannot find any switches under the unit.
AlamSAsif
- x 6945
I think on the RT6, the microswitches are here, circled in red:
AlamSAsif
Hi Marc. there are 2 solder points in this place. No Micro switch.
- x 6945
As far as I know these should be switches - very small and barely noticeable - but when pressed with the boot CD in and the vehicle connected, it should start the bootloader mode.
AlamSAsif
Please see the picture. May be it's the model difference. Thanks
- x 6945
Possibly - I'm wondering whether these are accessible internally from the opposite side of the circuit board? I don't have this unit personally, so can't check myself. Just be careful when disconnecting the leads if you want to check, Take off quad lock first before any other cables as that is the power, and reconnect last. Also mind the ribbon cable internally when you take the case off.
AlamSAsif
These points are just under the SD card reader. I am unable too see the micro Switches on circuit board.
AlamSAsif
It did do something for around 15 min. I can hear the CD spinning sound. But after around 15 min it restart and then stuck in boot loop. But nothing on display for all the time. I can see only back lit on the display. Thanks
AlamSAsif
This time it rebooted in 15 min and then start doing something again. I can hear cd spinning . Let's hope it finishes successfully. But nothing on display. Thanks
AlamSAsif
Hi.
After more than hour waiting and 6 times reboot still nothing works. I also check the SD card and there is no partition created, I think the update is not working at all. Please see picture. RT6 reboots 6 times. I was thinking to update through USB but the CD is stuck in the RT6 and eject didn't work. It start spinning again after every reboot. Don't know what to do next.
- x 6945
Ok, so there are 2 versions of the RT6 - one with Micro switches and one with the solder joints like you have. The system is trying to boot and is getting stuck in a cycle. If you have the new firmware CD inside the unit, then shunt the 2 solder points to start Bootloader mode and then while shunted, plug the power connector in.
With a bit of luck that may start the process - but no guarantees.
AlamSAsif
I tried it Marc but still stuck in same cycle. I manage to eject the cd and create a usb for firmware 2.77 and when I restart RT6 and after few seconds the display turn on and showing CRC Media Checking.... With the Peugeot logo in center. Let see what happens.
I was checking the files in the old SD card and in couple of files the firmware was 2.70. So I thought why not start with 2.77 and then if all works then gradually upgrade to next up.
