C4 MK2 Drivers door Check strap
NAM
Unread post by NAM »
When I open the drivers door there is a "clunk" and after spraying oil and grease onto the hinge and check strap I think that the issue is with the check strap - I held it and felt the clunk.
So, is this an easy job - one part goes into the door so do you heave to remove door panels. Has anyone else had the same or similar and how did you resolve? I think that a might need a new drop link as there is a little rattle so maybe this is also a job for a garage?
Any tips or comments much appreciated.
NEW 50 Shades of Grey C5 Tourer 2016 BlueHDi 2L VTR+
C4 (62) 1.6HDi VTR+ (Feb 2020)
Silver Dream Machine: C4 Hatchback, 1.6 SX HDi (07) (July 2013 - Feb 2020)
C5 Tourer Exclusive 09/2Ltr HDi (Oct 2012-Sept 2021 146K miles
Xantia Estate Mk2 1.8LX V-Reg/2000 173K miles.
gwest
x 20
Re: C4 MK2 Drivers door Check strap
Unread post by gwest »
I'm surprised that you had no responses to what appears to be a common problem with Peugeots and Citroens going back over many years. There are many YouTube clips showing how people tackled it. I have the same problem on my 2013 DS5 and will leave it until it starts rattling when I'm driving it. But yes the door card has to come off so you need to know where to prise covers off to expose screws. And you will need to break the seal of the inner plastic waterproofing membrane, and reseal it. Removing the check strap itself seems to be straight forward. But I am surprised that PSA did not address this problem.
x 1955
If the door strap is the same or similar to the Xsara that preceded it then check the screws that hold the strap on to the A-post are tight. If they are loose a little bit then opening and closing the door gives a sharp "crack" noise.
EDIT
Just noticed this is from last February! @NAM hope that the problem was sorted.
NAM
Sorry - ages to reply but a belated thanks to both for messages. Yes it is now resolved - I had a new one fitted! Car is going great guns at the moment. I had to have a new front OS window winder mechanism fitted as the old one broke but apart from that all is well.
