The relay was very difficult to start - turned over fine, but wouldn't fire. After a lot of cranking it did fire, but then started making the noise in the following video https://drive.google.com/file/d/1YW6sie ... p=drivesdk
I checked the oil and it was very low - Topped it up but noise remains.
Have I destroyed my engine?
Citroen Relay loud engine noise
- My Cars: Citroen Relay
- white exec
Re: Citroen Relay loud engine noise
Does sound very sharp - metal-on-metal.
Are you sure the oil level is correct? Is the dipstick all in one piece (there have been damaged ones)?
Any dash lights - eg oil pressure warning light?
What does the oil look like on the dipstick, eg any contamination?
Any unusual smell at the oil filler?
Do post your VIN, so we know the exact engine you have.
Been looking at it a bit further - looks bad! I'm thinking timing, but why only 2 cylinders?
https://drive.google.com/open?id=1YeVZy ... bJmS-8xqZa
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
- white exec
RELAY III VAN LONG WHEELBASE H3 TYPE 16 2.2 HDI 120 PUMA Manual gearbox 6
Looking at that second video - loose injectors? Other folk here will know that engine better than I do.
- My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl - x 994
Looks like those 2 injectors are loose - when we had a blowing injector on ours I thought it was a worn cam lobe to start with!
Appears that they share a clamp and a single bolt, good chance the bolt is loose or broken
This is the 2.2 engine from the Transit, I found this on another forum:
"Im a ford tech in a main dealer, I have seen this bolt snap only once, that van had a new head and injectors as the injectors bouncing up and down smashed the mating surfaces, I have never heard of a repair kit, recall, tsb or fsa.
egr faults are very common, injectors go now an then, if your revs hunt at idle, or bob up and down then I would be looking at a pcm update. Now and then a dodgy imv valve will cause the fuel rail preasure release valve to operate, not likely for you as you have not complained of any other running faults
Timing chain faults seem a thing of the past now, not had one on the new puma engine, timng chain, tensioner and rockers are all different, tensioners failed more on old 2.4."
I'd get the injectors out and have a look at them....
Thanks guys,
Injector clamp bolt was loose. Tightened it up and noise has gone and starting now easier.
Given it was loose I guess I should be replacing the copper washer, but at least it now sounds normal again.
Thanks for all your help
Oliver
Oliver
- white exec
Do replace the sealing washers; they've probably been hammered.
Hopefully no permanent damage.
