DS7
- x 5683
- x 2007
Re: DS7
C5x7 dropped that warning light on the screen wash as well....and the bonnet auto-lift rams.
On the Xantia V6s1 cars they had a low engine coolant sensor installed, all the wires in the loom but forgot to add the connections to the warning lamp on the dash (also installed)
- x 6950
Re: DS7
The X7 does have a washer fluid level sensor (8) for the headlamp washer reservoir on vehicles equipped with Directional Xenons as these obviously use a lot more fluid.Stickyfinger wrote: 28 Feb 2020, 08:38 C5x7 dropped that warning light on the screen wash as well....and the bonnet auto-lift rams.
- x 6950
Re: DS7
I've often been caught like this on longer journeys where the roads are covered in sleet / mud / grease / and spray from traffic - despite topping up the washer tank in the morning, and getting the warning on later - so have to turn off main headlamps from AUTO, to sidelights, squirt the windscreen, then put the lights back to AUTO so I don't run out. When the headlamp washers activate, they go! 2 Extended wash jets per cycle, so can eat through washer fluid.
- x 1953
Re: DS7
Drink surely?
