Hello all,
I am new to the forum,and my name is paul.
I am having difficulty removing my ds3 blower fan,or heater fan for the cab.I have taken the glove box off and found it,and unplugged the connection, but cannot remove the fan unit.It looks like it twist off,but I am not sure.I brought the replacement fan,but cannot see how the unit comes out.
I would be so grateful of anyone help please.
I hope it's not dash off,but I cannot see any connection screws between the unit.
Regards paul
Citroen ds3 blower motor
- x 3304
Re: Citroen ds3 blower motor
Hi, and
to the forum. I am not going to be able to help you with your problem, but I feel certain somebody will be able to advise you.
Citreon user
Thanks,hopefully some one will may have experienced this as well
- x 6956
Are you sure you need to take the fan out and not just change the blower motor control unit?
Remove:
The (10) bolt
The heater matrix pipes retaining plate (11)
Unlock: The blower control module (12) (Quarter turn).
Disconnect the connector ( as "c").
Remove the blower control module (12).
If it's the actual motor you are sure you want to remove then diagram below:
Remove the bolt from the air duct.
Move aside the air duct.
Remove:
Remove:
The (10) bolt
Remove:
- The (10) bolt
- The heater matrix pipes retaining plate (11)
- The air blower (Turn a quarter of a turn)
