Hi
I need to know the part no. Of the car door lift as it makes noise in closing and opening the doors it is one at each door for car Citroen C4 Grand Picasso 2015 new shape
VID: VF7**************[VIN obfuscated, can be read by forum staff]
Hesham
Car Door Lift
- x 1751
Re: Car Door Lift
I'm sure you'll get some help with this one.
Could you Edit your profile, so your full address isn't shown in Location?
Just 'Cairo, Egypt' will do fine. Thanks.
- x 6954
Re: Car Door Lift
What are you referring to? The hinge (item 3)?
Generally, just lubricating these with some silicone oil spray and some marine grease would likely solve the issue.
Note: I've removed the full address from your profile.
heshamderbala
Re: Car Door Lift
Hi
For the profile i will edit , thanks
I think the part is no.5 as the door is handeled by one upper and lower arms and the issue i face is with the black part in the middle of both and all lubricans doesnt work
Hesham
Hesham
Hesham
Hesham
heshamderbala
- x 1751
Re: Car Door Lift
Sorry, Hesham, this seems to have got lost - apologies!
Item 5 is 'DOOR STOP'
Often known as a door stay. It makes a 'clack' noise when door is fully opened, and stops it swinging shut.
The mechanism can wear, and need replacing.
Front doors, L&R: 96 763 451 80
Rear doors, L&R: 96 761 173 80
heshamderbala
Re: Car Door Lift
Hi Chris
Is it a common fault in the car as i can see in my country the Engineer in the service center is telling me that too many Citroen cars have the same issue
Hesham
Hesham
- x 1987
Re: Car Door Lift
They have been doing that since the CX in the 80's
You can trust Citroen to keep the same problem going
heshamderbala
- x 1751
heshamderbala
