Hi
As some of you will know from previous posts I have just retro fitted a sat nav system (myway) to my 2009 C5
I am having trouble with the microphone! I have fitted two used ones and unfortunately non seem to work.
I have read several posts that possibly point to the mobile phones compatability, I would appreciate any assistance on this matter
Please see photograph of firmware
How do I update the firmware?
Thank you in anticipation
Regards
Steve
Update
EDC5
- x 130
Re: Update
Did you install the wiring for the microphone yourself or use the preinstalled wiring?
I installed a sat Nav in my C5 and although I already had the microphone wiring preinstalled, it didn’t actually lead back to the headunit connector. I had to run my own microphone cable.
Steveo
- x 13
Re: Update
Hi
Thank you
The wiring is connected behind the light and I think the microphone wire is connected to the unit so there must be a connector somewhere else
How did you wire yours and did you use the original microphone
Thx
Steve
Thank you
Thx
Steve
- x 6945
Re: Update
It's probably because you had a standard RD4 system originally, so no telematics and no hands free kit or emergency assistance kit - so your front fascia wiring harness was different (part: 6586 Q0). Other systems have different harnesses - so although the microphone is there, it probably doesn't have the connection into your particular wiring loom. Best thing you can do is manually wire the connection to the quadlock connector directly.
EDC5
- x 130
Re: Update
This thread here has my C5 car audio journey in it: viewtopic.php?t=58078
I think I've got some diagrams in there of which terminals on the back of the myway, I believe they are the same terminals used on the RD4 and RT4.
I did use an original Citroen microphone installed in the proper location but as you will find in that thread it was impossible to trace the other end of the preinstalled wiring so I had to do it myself.
- x 6945
Re: Update
Yes, there are so many wiring harnesses for these depending on kit - so although the mic is there, without the hands free kit fitted for the older RD4 systems, or the emergency services module (that takes the mic wiring), or the dedicated harness for the telematics system, it's probably not attached.
Steveo
- x 13
Re: Update
Hi Marc
Forgot to mention that if I press the end of the light stalk I get a voice message saying navigation is not active (or something similar)
Don't really know what that means on a Citroen not the message but the equipment fitted
On the 407 it meant I had voice control but as above don't know about the Citroen
Regards
Steve
Regards
Steve
- x 6945
Re: Update
Hi Steve. Ok - so on the X7 with a telematics system fitted, pressing on the end of the lighting stalk repeats the last navigation instruction.
If you have retrofitted this unit, you will have to VIN code the unit to your C5 and also alter some configuration parameters to get it to work. At present, I suspect your BSI still has the configuration for the RD4 system and therefore it is confused.
If you have a Lexia / Diagbox I can probably help you do this - let me know.
Steveo
- x 13
Re: Update
Thank you
Appreciated
Pm sent
Steve
Thank you
Appreciated
Pm sent
Steve
Steveo
- x 13
- x 6945
Re: Update
Ok, thanks Steve - I will look at these and be in touch - just have a couple of things to do here then I'll get onto it.
- x 6945
Re: Update
Ok, so you need to change the following: For items listed as 'Missing' on your screen shots (Heating Ventilation / Under Inflation Detection), see if you can change these to 'Absent'. Otherwise the BSI may be expecting them if previously configured for the donor vehicle in the Head Unit ECU - where they are not valid on your C5.
That's all the options correct for what you have shown me.
There are some BSI errors showing, so when you have coded the parameters I listed above, (select option, then green tick, then from following menu select appropriate option, then press cog wheel to code it), - re-run the global test and let me know all the fault codes shown (see if the BSI ones are still there) and if so, what they are - along with anything else.
- Parking Aid to Absent
- Under Inflation Detection to Absent
- Heating Ventilation to Absent
