2.0HDI Picasso poor starting
- x 1485
Re: 2.0HDI Picasso poor starting
If you go into parameter measurement you should be able to see the engine speed. I think it needs to be at least 180 rpm to get a start, you also need the rail pressure to be above 200 bar or so, or it won't start the injection.
Michel
I recall it's the rail pressure not getting high enough with the slow cranking that's the issue. My Berlingo only just got the required rpm eventually but didn't get the pressure.
winchman
- x 11
Any idea which is the rail pressure as I am not sure what's what when reading the data?
I am hoping the RPM has RPM as the units?
- x 1485
Have you got diagbox? In which case it should be under engine ecu and then standard parameter measurement; you are looking for a big number in bars. Aftermarket scanners it might be something else, e.g. FRP - and I'e seen one recently where it was quoted in kPa, so it was a really big number!!
winchman
- x 11
I have a Blue Point Microscan
When cranking it reads zero RPM until it starts?
Would this bottom one be fuel pressure?
ekjdm14
- x 260
Yes that's Fuel Rail Pressure at the bottom. I also note you've had the EML on for 68km according to that tool, what faults are you getting? Could that be related to the starting perhaps?
Cranking RPM may not show on that tool but it is interesting to note... Perhaps you could try it on another similar vehicle & see if it registers cranking speeds there?
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
winchman
- x 11
The EGR valve has been stuck for about 4 years, turn the light out and it comes back after 30 mins or so
winchman
- x 11
Today progress, it wasn't cold but tried the jump lead from engine block to battery, not certain to be honest but went to the scrappy fitted an extra earth strap from block to Engine mount, did some one mention the filter housing and having to tighten it with a big wrench??? Well I thought lets give it a try, got almost half a turn on it, so let see how it is tomorrow
Huskyxantia
- x 891
Very true , had a similar issue but with a different car years ago , new starter motor and it worked the motors wear and slow down after a few yearsMichel wrote: 28 Jan 2020, 18:30 It's the starter motor. We did tell you.. this happens to so many of this engine...
Husky.
Huskyxantia
- x 891
Have you checked for vacum leaks at all, ?winchman wrote: 30 Jan 2020, 16:05 Today progress, it wasn't cold but tried the jump lead from engine block to battery, not certain to be honest but went to the scrappy fitted an extra earth strap from block to Engine mount, did some one mention the filter housing and having to tighten it with a big wrench??? Well I thought lets give it a try, got almost half a turn on it, so let see how it is tomorrow
Husky.
winchman
- x 11
I know but I need to be certain, I wont stop moaning for months if I buy one and it doesn't cure it!Huskyxantia wrote: 30 Jan 2020, 16:06Very true , had a similar issue but with a different car years ago , new starter motor and it worked the motors wear and slow down after a few yearsMichel wrote: 28 Jan 2020, 18:30 It's the starter motor. We did tell you.. this happens to so many of this engine...
I have arthritis in both hands so its a pain for me to remove it, I can refurbish it my self just fiddly for me to remove.
I do fancy one of the big fancy high output ones though.
winchman
- x 11
How would I do that?Huskyxantia wrote: 30 Jan 2020, 16:08Have you checked for vacum leaks at all, ?winchman wrote: 30 Jan 2020, 16:05 Today progress, it wasn't cold but tried the jump lead from engine block to battery, not certain to be honest but went to the scrappy fitted an extra earth strap from block to Engine mount, did some one mention the filter housing and having to tighten it with a big wrench??? Well I thought lets give it a try, got almost half a turn on it, so let see how it is tomorrow
Huskyxantia
- x 891
YouTube has lots of videos on how to do this its the same principal for all cars have a Goole how to find vacuum leaks with wd40 your find lotswinchman wrote: 30 Jan 2020, 16:09How would I do that?Huskyxantia wrote: 30 Jan 2020, 16:08Have you checked for vacum leaks at all, ?winchman wrote: 30 Jan 2020, 16:05 Today progress, it wasn't cold but tried the jump lead from engine block to battery, not certain to be honest but went to the scrappy fitted an extra earth strap from block to Engine mount, did some one mention the filter housing and having to tighten it with a big wrench??? Well I thought lets give it a try, got almost half a turn on it, so let see how it is tomorrow
Husky.
winchman
- x 11
I didn't know it had any vacuum stuff on the engine?Huskyxantia wrote: 30 Jan 2020, 16:17YouTube has lots of videos on how to do this its the same principal for all cars have a Goole how to find vacuum leaks with wd40 your find lots
Another thought to consider
Huskyxantia
- x 891
Reason: Video link
Reason: Video link
Husky.
