307 1.6 hdi disable chinese alarm
Slobo2712
When I bought this car it was comed with some kind after market built alarm system.Now Im interested how to completely disable this aftermarket alarm and re-enable stock key locking because now stock key lock buttons not respond at all.Tnx
- x 6963
Re: 307 1.6 hdi disable chinese alarm
That will be difficult for us to help you with as there is no way for us to know what system has been fitted, what it does and how it has been wired in......
You'll need to do some investigative work or take it to an auto electrician.
Slobo2712
Tnx for answer.I have found this cable isnt connected anywhere.How to know for what purpose is?
- x 6963
Have a look on the green and purple wires - along the sleeve - can you see any numbers? The wires usually have some codes to identify them. You may need to look quite a way up the wire along both sides. That might help us.
Slobo2712
I think its not readable on the wire
- x 6963
Ok, so in the snip below, can you gently clean the oil off as that looks like there may be some writing / codes on the wire where I have arrowed in yellow. I can't read it as there is too much dirt!
Slobo2712
I have tried that but letters seems that are faded away
- x 6963
Ok, it is usually the numbers and a letter - but the sequence is repeated on the wiring sleeve - so you may find a clean spot under the black insulation further up. Without this it will be very hard to identify - and even then there are no guarantees. Have a look under the black masking tape a little further if you can.
Slobo2712
Ok,I have followed wires to the end and here are numbers on it
Purple 723766 1710
Green 723766 1410
Purple 723766 1710
Green 723766 1410
- x 6963
I'm not having any luck to be honest - the only codes I can locate for the last 4 numbers are:
1410: turbocharging solenoid valve earth 2
1710: electric cooling coolant pump supply
But I can't actually tie 1710 back to anything on your vehicle, only 1410a and 1410b which are the earths to the tubocharging solenoid valve (s).
Slobo2712
Thank you very much,I have one turbocharging solenoid valve really dont know does this engine need to have more?
- x 6963
It may just have the one.
Slobo2712
Ok tnx for help.This is only what i have found below steering wheel,I think its alarm sensitivity.Not other box or switch for disabling.
edit
It does not bother alarm to me,just want to replace this unlock car switch
for this normal one
edit
for this normal one
- x 6963
It makes me wonder why they put that there on the first place!
You’ll just have to trace the wiring back to see where they have bridged the connections.
