C4 Pic 2014 Exclusive (B87) - Rear Light Unit Removal & Replace
zane2g2
Unread post by zane2g2 »
Afternoon all,
I was wondering if some one could advise on the removal and replacement of the rear light unit (fixed to the boot) on a C4 Pic 2014 Exclusive (B87) please.
This is the standard 5 door version NOT the Grand Picasso version.
Many thnaks
Zane
x 6947
Re: C4 Pic 2014 Exclusive (B87) - Rear Light Unit Removal & Replace
No problem...
You'll need some trim removal tools to help. They recommend disconnecting the battery first (follow this guide BSI Reset / Battery Disconnect / Reconnect Procedure)
Removal
Unclip the cover (1) ( at "a") using trim tools.
Remove the cover (1).
Remove the bolts (2).
Disconnect the connector (at "b").
Unclip the tail lamp (3) (at "c").
Detach the rear lamp unit (3).
Remove the rear lamp (3) (In the direction of the arrow ).
Refitting
Proceed in the reverse order to removal.
Reconnect the ancillaries battery (refer to reconnection part of previous procedure).
Check the operation of the equipment.
zane2g2
Cheers @GiveMeABreak spot on job :-)
x 6947
No problem, glad you have it sorted.
