Going to do my clutch C3 MK2 2011, tips?
x 6945
Re: Going to do my clutch C3 MK2 2011, tips?
They are really professional tools - and are not cheap - Laser tools do them - but these often contain a kit with adaptors for a wide application of marques - so £400-500 is normal for this sort of tooling - so not something the DIY mechanic would necessarily have. They do seem to be widely used: Here's an example of one:
ultra2extreme
Unread post by ultra2extreme »
awesome vid, loks like something like this would do for my purposes
https://www.ebay.co.uk/itm/Self-Adjusti ... Sw9sBc-Olb
x 6945
Well the good news it that has one less '0' at the end of the price than most!
I hope they have a suitable adaptor for your C3 - maybe worth checking.
ultra2extreme
yeah man i will do although itll still be a gamble as no doubt this stuff comes from china. While ive got you here is there any chance you could look up what EOLYS my car needs from the VIN for me? As that warning has just come on too! great!
x 6945
Yes, your C3 Picasso uses POWERFLEX additive. It is the pouch type. The part number is: 9678033980 and these are 1.1 Litre pouches.
x 1488
We put a new auto adjust clutch in my mate's C5 - didn't use one of these tools and it was fine afterwards. I can't really see what it's doing TBH - the pressure plate is like 1/4" thick - as long as you carefully tighten down the bolts evenly then you are not going to distort the plate. Maybe I am missing something....!
x 1488
This: https://www.repxpert.com/en/mediadocume ... ecBr-PC/en contains lots of info about Self Adjusting clutches. This is the only bit which references the reason for the setting tool
Using a special tool is an absolute must to ensure correct
installation of the Self-Adjusting Clutch. No counteracting
forces must be applied during installation to prevent early
rotation of the adjusting ring in the clutch pressure plate.
I'm unsure as to how you would apply counteracting forces to move the ring.... but maybe if you pull the pressure plate down against the spring there is a risk that it upsets the SAC mech. If you can get the tool for not too much cash, then it seems worthwhile to avoid having to get the box out again!
ultra2extreme
Thanks for all the help guys, have ordered the tool, makes sense! if i can, i might try to video the procedure for people to look at later, there really isnt loads of info on this process out there, doesnt seem too complex
ultra2extreme
Ok, im mid way on this, going fairly well, one ballache was that one of the selector rod connectors seems to have popped or broken on removal :/ looks like i can secure it but may need to do something with that.
im struggling with something really REALLY dumb, where is the starter motor, i cannot see it for the life of me. Additionally trying to figure out which bolts attach the gearbox to the engine, itr really isnt all that obvious. any tips??
Reason: Changed Images to FCF Hosted
ultra2extreme
this??
x 6945
Here...
x 1488
That's it in the pic. Getting to the top bolt is 'interesting' to say the least. Although it's not shown in Marc's diagram, there might be another bolt in from the other side, invisible under the stat housing.
x 1488
The first pic in the reassembly section in Marc's post with the procedure shows the location of the engine/box bolts.
x 1488
You might be able to glue that ball joint back together, but I rather suspect it's had it... unfortunately it only comes as a complete unit:
It's just a smidge under £250 from Citroen however.... scrapyard might be a possibility!
ultra2extreme
Thanks guys!
Yep starter was a ballache you def need a heck of a selection of tools as you only have about an inch of range to get a handle in. Not too bad tho once i got the wiring off.
Second annoyance was the top bolts on the gearbox, they are obstructed by a rather firm wiring harness that is itself bolted to the housing, once thats off however the top 2 bolts become accessible.
I didnt have to take off the exhaust downpipe as some had suggested, there was a nut and stud to be removed and then the gearbox bolt was accessible.
I did take off the cooling fan as it gave loads more room id strongly recommend this, although it did involve removing coolant pipes so i just drained the coolant system since it was on my long term to do list.
And as for that connector im gonna put everything back together and see if i can bodge a solution for now. Popping those off was a lot harder than had been suggested i prob should have bought some ball joint separators
Now to pop off the clutch and take a look compare to new one and hope the effing match!!
