Peugeot 107 power steering control module
michael maurice
Can anyone tell me where the power steering electronic control module is on a Peugeot 107 (06 plate) and how to remove it?
ekjdm14
- x 257
Re: Peugeot 107 power steering control module
I'm afraid I can't help with the location, except to say that Service Citroen has the ECU on the same diagram as the rack suggesting it's located above the rack... What I will say though is, why do you need to remove it? Have you conclusive proof that it's faulty? Only, I've recently been looking into the EPS on my mum's car which is also an '06 107 (on 24k miles) and there were numerous inconsistencies with the amperage draw measurements in Diagbox and occasional limp mode with the only fault listed as being a speed sensor associated with the EPS ECU.
In that case I believe it was the vehicle's original battery beginning to fail (after 14 years!) and causing the fault.
'96 ZX SX 1.9TD, White, 88k
'98 Ford Fiesta 1.3i 72k
- x 6955
On the 107 with electronic Power Steering, the ECU is actually located in the upper dashboard Danmichael maurice wrote: 19 Jan 2020, 00:09 Can anyone tell me where the power steering electronic control module is on a Peugeot 107 (06 plate) and how to remove it?
The Control unit is (2)
The ECU is (4)
michael maurice
The battery is nearly new and the diagnosis has been made by an auto electrician who tells me the battery and alternator are fine.ekjdm14 wrote: 19 Jan 2020, 11:16
Thank you to GiveMeaBreak for his advice.
ekjdm14
- x 257
Aha, thanks for pointing that out Marc
I had a feeling near the rack was a strange place to locate a sensitive ECU. How do I access the actual layout like you have, is that the paid subscription part of Service Citroen?
Does the auto electrician have Diagbox? I know these do have a history of EPS issues (mainly the Aygo badged version from what I've read though, at around 24-25k) but would be interested to know what symptoms you have and what codes he's found please, for possible future reference as much as to hopefully help out here.
- x 6955
To be fair Dan, some are actually mounted on the steering rack so are easier to access.
