Hi, my daughter has a 2004 C2 3 dr, the same key unlocks her drivers door and the ignition, the door lock needs to be replaced as its worn, she has no remote for the car.
Can the drivers door lock just be replaced? i know she will have 2 seperate keys
Only replacement locks and keys i have found are for the passenger side (no lock on her car on that side) .
Can i fit a passenger lock into the drivers door side?
Thanks for your help
C2 3dr 2004 Drivers Door Lock
- My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl - x 982
Re: C2 3dr 2004 Drivers Door Lock
Welcome!
If you can post up the VIN (it will auto hide) we can check what is fitted, and get part nos for replacements. It might be possible get a lock from Citroen with the correct key - for a price!!
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5644
The locks are standard on the 3 door range:
Part numbers form Citroen:
9170W3 Left Lock
9170W4 Right Lock
These are currently priced @ £58.08 each inc. VAT and the key combination is specified on order (so you can use your existing key). But the fitting is another issue.....
9170W3 Left Lock
9170W4 Right Lock
