Looking at a scudo for someone.
He was driving, hear a noise from engine area and it cut out.
Can see cam shaft turn over when turn key/engine over
Put a good battery in it, engine sounds weak turning over, gets slower , picks up, slows, picks up etc. Its a really good battery, but it sounds like the battery it's about to die or poor starter motor
He has mixed two different anti freezes recently
Coolent is below minimum
Someone has changed gear box recently
It's a 2004 1.9d 124k
A friend has suggested possibly the water pump has seized and the belt may have jumped a tooth
Looking for members thoughts, any common issues with these to look out for.
Scudo dead
- white exec
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Scudo dead
It's because it is the same vehicle as a Citroen Jumpy / Dispatch or Peugeot Expert Chris - they are all essentially rebadged Fiats - and later with Toyota.
But the VIN will be from Fiat itself, so we won't be able to determine exact specifics which is not going to help you I'm afraid Soulfly83.
