My 2015 308sw has developed a problem: the eco-mode comes on when stationery but the engine does not restart when I press the clutch in - I have to press the eco-mode button to restart. No problems with changing gear.
Has anyone else had this problem or know what it may be?
Thanks.
Eco mode not cutting out when declutching
Onlinemyglaren
- x 5672
Re: Eco mode not cutting out when declutching
Hi and welcome to the FCF.
Could you post your VIN here to help identify the installed systems for your car which makes identifying faults more precise.
Your VIN will automatically be obscured and only readable by the forum admin team.
- x 6945
So obviously you have the stop and start system.
There can be many reasons why the system won't start, primarily these are:
Does the ECO button flash at all or does it stay on or off?
- Traction chain closed
- Power accumulator charge status inadequate
- Low battery charge status
- x 1939
The most likely item to be at fault is the switch on the clutch pedal which signals when the pedal is depressed. Using a code reader which can monitor the system properly will show whether the switch is working. The recommended reader is a Diagbox as lesser readers might not be able "see" into the system as deeply as required.
Another way of restarting the engine on our car when the S&S has kicked in is to turn the steering wheel slightly. Does this work for your car?
