C5 X7 cabin temperature LCD - missing pieces
jontech
x 4
Unread post by jontech »
Good evening all!
Have missing pieces of the lcd for cabin temperature. Is this possible to fix without replacing the whole board which also has the dials and buttons?
Jonas
x 6945
Re: C5 X7 cabin temperature LCD - missing pieces
No, these are complete modules with no user serviceable parts. If you’ve checked the electrical connection to the plugs then you will probably need a replacement unit.
x 1996
Unread post by Stickyfinger »
Maybe Simon in Somerset can fix them ? He seems very popular with C6 clusters
x 6945
He's in Sweden Alasdair :-D
The C6 instrument clusters were well-known to fail - but I think the Climate panel is pretty much a new unit.
x 3565
If it's the same as the one I took apart on this thread:
viewtopic.php?p=576809
Then they're surprisingly disassembleable (is that a word ?). I've still got the old one in the garage if some advanced level butchery is needed :-D
jontech
x 4
Thanks for the replies!
Ok, so first thing to do is to check the status of the connectors, and maybe clean a bit. If this does not help I might have a look at the seamingly disassemblable panel and see how complicated it seems. From just now reading out a bit on lcd panels, missing pieces can be a result of bad connections.
Yes, based in Sweden. Thanks for a great forum, been reading a lot here during the years.
Jonas
