C5 problems - Here we go again
mikal
Unread post by mikal »
Well 4 years ago the starter motor blew, many hundreds of pounds later done.
Then the windscreen wiper motor went
Then the tyre pressure sensors.
2 years ago all the bongs etc started and the cruise control, ebs or whatever packed up, happened if you braked hard. Analysed the codes and an engine ecu failure is the culprit.
Last year the gearbox played up. It would just stop and/or stay in 1 gear and I'd limp home. Then it would sort of drive OK for a few months and ....as it did today. Happened again, fortunately just a few hundred yards from home. I've now got zero faith in it so it might be time to say adios.
Its the 2.0hdi auto diesel worth.........norra lorra I'd guess. 2008 and with 80k miles, the "exclusive" model. Worth what 1.5 2k on a good day, in good nick, ((which it isnt). Is it time for the scrappy? I am thinking of a Octavia estate/focus estate. WE need a similar sort of car in decent nick that can pull 1.5 ton of wood and a decent interior etc for the occasional long journey. I wont do more than 2k miles a year. I think I've knackered the auto box pulling too much weight. Waddyathunk
x 1751
Re: C5 problems - Here we go again
Hi mikal,
Have just edited out the above post from "Off Topic", and left it here, with title tweaked.
Hope OK.
leithant
x 9
Unread post by leithant »
X7?
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased :-(
x 1240
Unread post by Peter.N. »
Sadly the C5 X7 is not the most reliable car in the world but the ride is so good I am prepared to put up with its idiosyncrasies, I haven't found another car that is so comfortable and quiet, but I have gone for the least troublesome models, that includes steel springs - which still ride superbly, in fact I would suggest that over small road imperfections its better than the hydropnumatic ones, manual gearbox, 2.0. Hdi engine and the estate version, these are the ones that are making the most money - and in fact selling.
I have bought two of them this year, the first was a VTR+ which has a leaking steering rack but the loss is so small that I just top it up when necessary, the wipers have been playing up lately but seamed to have healed up for the present. The second one is similar but has a top spec interior, leather seats, satnav etc, that one has been off the road for a while to sort the thermostat out but is now going again so we have a spare if the wipers pack up on the other one again.
I probably couldn't afford to run them if I was unable to repair them myself, which I still can - just about. You can get a new starter motor on ebay for about 60 pounds and replacing it is probably one of the easiest jobs on the car, takes about half an hour.
I ran hydropnumatic Citroens for about 30 years from the CX onwards, my last CX 25 DTR turbo Safari had a porous block which necessitated replacing the head gasket every 15k miles, I ran it for about 160k, that's about 10 head gaskets but they were fairly easy to change and I was prepared to put up with that because it was such a beautiful car to drive. The X7 has similar double wishbone front suspension, except for the springs and I'm sure that is at least partly responsible for the excellent ride and straight line stability.
Sorry to hear about your problems but I know how frustrating it can be.
If you look on ebay under C5's, at the top lefthand side of the page look at the list of 'tick boxes' under sold listings and that should be an indication of what yours is worth.
mikal
errrrrrrrrrrrrm thankyou. I think!
x 1751
Still unsure exactly which model of C5 is the problem here...
x 6963
He has an X7 (DW10BTED4) and AM6.
@Mikal:
Your choice really - but without proper diagnostic codes we can't really advise as we won't know what the cause(s) are. There are over an hundred fault codes that can appear with the gearbox alone - might be something simple or might need a new valve block, or just an oil change.... you get the picture.
Once you have some idea as to what is wrong, you'll have to weigh up possible repair costs against getting another vehicle and any potential hidden baggage that this brings. If you are considering repairing it then please get it diagnosed, post up the fault codes.
@Chris: I moved this originally out of the technical forum and into the Off Topic Lounge as it didn't seem to be asking for technical advice, but a recommendation for another car. If that is the case, then I'll move it back.
mikal
Marc.
Not really asking about another car, (although a focus/Octavia estate look favourite). I can take it to a local shop where they have a fault code machine and I know the owner, so that going to be next weeks job. WE bought the car as a caravan tug, and now just use it towing a trailer full of wood locally and the very occasional long trip. I personally think I've knackered it!
Cheers
Mike
On what is the car, says in the profile next to your name doesnt it!
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi Mikal, did you post on Pistonheads? seems familiar :)
My X7 was used for caravan towing, before I bought it. Gearbox is poorly now but works ok in Manual mode.
to all, assuming valve block problems, what kind of job is changing this unit ? Can it be done in situ? Can the old one be removed and sent off for repairs? I don't really know how to diagnose lack of shifting / compared to flaring, and if the valve block could be responsible for both.. if both symptoms are present, does it point to valve block and clutch pack issues? or am I forgetting the TC too...
x 1240
The Skoda superb apparently gives a very good ride and has loads of space but I went for the Citroen on the basis of the devil you know.
mikal
jgra1.. yes I did, but then again being pistonheads replies will tell me its all my fault! I note that the x7 can tow 15ookg, even the auto, My caravan weighed 1350 and we never really put much in it, so doubt we went near 1500kg. The wood and trailer we use is probably around the same, but its piggin hilly round here in East Cornwall which doesnt help.
Will be doing the inspection probably after the NY ho ha. We dont use the C5 that much now, and its just a workhorse.
Pete. It will probably be "retired" if the gearbox problem reappears again. I cant risk the car stopping and throwing a hissy fit with a ton of wood behind blocking a country lane. Its got a few dings and dents. I reversed it into a lamp post and the chrome strip is bent and fecking expensive to replace. Also most journeys now are less than 10 miles, so.........diesel/dpf......etc problems "could" be simmering under the bonnet.
Cheers all and a happy Chrimbo. And for those that know SLIB!
x 3281
One thing that DMFs 'hate' is reversing with a braked trailer. If you have such a trailer you need to look at (when reversing) disabling its' brakes to stop them locking and putting an increase of load on the DMF.
mikal
UPDATE Thought I'd give it a go today after sulking in the garage all night. On start up, the "depollution" sign popped up and a series of bongs and the engine check light. I drove no more than 4 yrds and it played up as before, but managed to do a ueeey and freewheeled home!
x 1751
Hell Razor5543 wrote: 24 Dec 2019, 05:45 One thing that DMFs 'hate' is reversing with a braked trailer. If you have such a trailer you need to look at (when reversing) disabling its' brakes to stop them locking and putting an increase of load on the DMF.
They also hate reversing uphill, or even steep forward hill starts.
In fact anything that requires the clutch to do a bit of hard or precise work.
The best thing I ever did on our RAV4 – after two failures – was get rid of the damned thing. :gt:
Not always an option, though.
mikal
Could the dpf be playing up and its gone into limp mode?
