Part number required (again) please
Benscab123
x 3
Unread post by Benscab123 »
Could someone please tell me the part number for the metal bracket that holds the headlamp bulb in place please (dipped beam). Thanks
x 1492
Re: Part number required (again) please
Not sure exactly which bit you mean, but I don't think it will be available separately, as only the complete headlamp is listed:
A new one is a snip at £310.....!
Benscab123
x 3
It’s the metal clip that holds the bulb in place Richard. Don’t see it on here.
x 1492
Ah, these are different - the bulb is an H7 and is restrained by a 1/4 turn. There must be some sort of clip on the back of the lamp, but I can't remember if it will come off or not. I always had to get a mirror on the OS to get the bulb back in as I could never remember which way to turn it!!
Benscab123
x 3
Something similar to this but with a rectangular hole .
Benscab123
x 3
x 6945
That's the wrong light anyway Richard :-k
Should be this one:
Not that it shows the bulb clamps either though...
Edit My bad - I was dealing with another vehicle - wrong post! :roll:
x 1746
As those clips are not actually attached (unlike the wire versions), maybe they are available as a spare part.
If not a Citroen part, maybe a Valeo one?
x 6945
I've had a look at Valeo's automotive lighting catalogue and there;s nothing listed apart from the bulbs themselves that I can see.
x 1492
GiveMeABreak wrote: 16 Dec 2019, 11:33 That's the wrong light anyway Richard :-k
Should be this one:
One I posted is for a Mk1 C4 Pic (as per the OP's cars list), yours is a C3 (?) Marc, but since the OP didn't specify, we could both be wrong! However, given the pic later posted of the clip, I rather think I am right this time....
x 1492
x 6945
Yes, wrong post Richard! I've edited my post as I was dealing with another issue on a C3 at the same time :roll:
Benscab123
x 3
Thanks guys, got them on order.
