My dad’s car, Gwin, (1.1l, 1994) has lost cranking completely and suddenly. Starts easily with a bump start. Battery fine. Thinking starter solenoid or ignition switch? Does the steering wheel have to come off to get cowling off for access to the ignition switch?
Ax non-starter
Jaf
- x 42
Ax non-starter
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
moizeau
- x 429
Re: Ax non-starter
Before going there check you've got a live and an ignition switched live to the solenoid. You can also short the solenoid or run a temp feed. Make sure it's neutral, don't want to run yourself over. Check the battery to engine earth as well.
Pete
- x 1751
Re: Ax non-starter
Hi Jaf,
Before removing the steering wheel or IGN swutch (not an easy job), make an electrical check to see
(a) is power reaching the starter motor solenoid (the small terminal on the starter motor) ?
(b) can the starter motor be made to operate by making a direct connection from this small terminal to Batt+ ?
This should point to where the fault is, and whether the starter motor and its attached solenoid are working or not.
Someone here might be able to post a (starting) circuit diagram for the car. Post the car's VIN so we get the right diagram.
Jaf
- x 42
Re: Ax non-starter
Right ok will check starter first. Tomorrow when it’s light. Will be novel to work on a car with room in the engine bay!
Dad’s just been taking a hammer to the steering wheel nut...
moizeau
- x 429
Re: Ax non-starter
Good job it hasn't got airbags then! Do all other electrics work, dash lights, headlights etc.?
Pete
- x 1488
Re: Ax non-starter
Give the starter a good clonk with a hammer handle before you do anything - sticking brushes or solenoid can cause just this sort of odd failure.
Jaf
- x 42
Re: Ax non-starter
It’s the ignition switch...wiggle the keys a few times and she starts.
Dad can’t get the steering wheel off though. He’s left it with slightly dicky switch for now.
Thanks everyone.
Thanks everyone.
- x 1751
Re: Ax non-starter
If the IGN switch proves impossible to remove (some are very difficult), one modification alternative is to allow the IGN switch to turn the IGN on (as normal), but to fit a 'push-to-start' button somewhere convenient on the dash. This would simply route batt+ to the small terminal on the starter motor. You could also add a 30/40A relay to take the load off the switch.
A couple of nice-looking engine start switches on Amazon.es ...
Jaf
- x 42
