Smokey Dispatch Mk2
AnthonyExeter
Re: Smokey Dispatch Mk2
Unread post by AnthonyExeter »
mine doesn't look like that.
x 6953
Yes, sorry about that - the one I put up is for a DV6 variant with a particle filter - which you don't have on a 2007 model. It was just an illustrative point as there were a lot of variants to this engine and they don't cover all the nuances.
This one is yours - a much cut down version.
AnthonyExeter
ah cool, do you have a close up of the body and a labeling of the sensors.
x 6953
Not for this model - or I would of put that up initially for you... sorry.
AnthonyExeter
no worries, thanks for the pic anyway. I bought a Haynes manual but was really disappointed with the low quality, nothing like the manuals of the past.
AnthonyExeter
Any ideas why torque pro would be reading an increase in inlet manifold pressure while driving, shouldn't it be going down?
what are the likely causes?
x 6953
Because the air pressure inside the manifold is lower than the ambient air around the engine. So if you have a leak, then the manifold will actually be sucking additional air in from the location of the leak.
You may possibly hear a gurgling, sucking or swirling noise - but maybe not. So an examination of the air hoses or seals may reveal something....
AnthonyExeter
but would that cause the pressure to rise above ambient?
i'll pop out in a mo and double check, maybe take a little vid of the various reading on my tablet.
x 6953
The air pressure is normally lower in the manifold - lower than outside temp - so therefore if you have a leak somewhere, this will cause air to be drawn in and therefore will show the air pressure increasing as you have detected on your scanner. This in turn will affect the readings sent to the engine ECU and cause it to try and compensate.
Too much air in the cylinder means less fuel - so a weaker explosion and consequently the engine has to work harder to turn the crankshaft. This will result in sluggish performance and use more fuel.
So worth checking for leaks.
AnthonyExeter
just been out and recorded this.
as you can see, very little movement on the intake pressure.
https://photos.app.goo.gl/42uL2yiPan3q6TEA7
x 6953
So the pressure doesn't seem to be rising then according to that.
AnthonyExeter
no, it was rising to 18psi while driving yesterday.
just been out and pulled the vacuum hose off the turbo and the arm is moving ok when reconnected
do those reading look ok? I was expecting the inlet pressure to drop more than that.
x 6953
I don't have the default values for this engine I'm afraid.
AnthonyExeter
Would i be better off getting a full diagnostic? How much should i expect to be paying?
Don't have any of this trouble with my trusty marinised 80's ford diesels. lol
x 6953
From PSA - they'll charge about £80-90 an hour.... so you may be able to wangle half an hour - or see if there is a member with a Lexia near you:
Here's the link to the member list with Lexia kits. Hopefully you won't need the commercial add-on module - but at the end of the list is a link to a Google Map. That will show member locations geographically for you. Contact them by private message - but be aware not all members are on line all the time, so may take a while to get a response.
https://www.frenchcarforum.co.uk/forum/ ... hp?t=56452
