Citroen dispatch 1.6
Louisking1
Have a Citroen dispatch van 1.6 hdi been having problems with anti pullution light coming on and stalling while in traffic. Have replaced fuel rail pressure sensor few months back it helped for awhile but has came back with vengeance’s lol. Help guys. Pics of fault codes below
Reason: Removed 4 duplicate images
- x 3283
Re: Citroen dispatch 1.6
Hi, and
to the forum. To add pictures to a post you need to use the "Full Editor and Preview" button, and then you will have the ability to upload images.
- x 5618
Editing the images
Louisking1
Thanks for editing I’m a newbie to the forum lol
admiral51
- (Donor 2026)
- x 394
Hi and welcome
Post your Vin number and it will be obscured to all but admins will appear as ************ to everyone else, trust me it will help them pinpoint what your vehicle left the factory with.
If you are unsure have a look at my profile, all my cars have the vin posted in it
Louisking1
No problem I’m posting on behalf of my brother I’ll get the vin in the morning and post on here thanksadmiral51 wrote: 11 Nov 2019, 18:56 Hi and welcome
If you are unsure have a look at my profile, all my cars have the vin posted in it![]()
Louisking1
One for the admins vin number is VF7**************[VIN obfuscated, can be read by forum staff]
Louisking1
Anyone got ideas of the faults would be much appreciated thanks
- x 6963
I'm just having a look now....
- x 6963
Ok, here we go...
Fault P1113: Intake air temperature signal (Air flow meter): Open circuit or short circuit to the plus. The voltage of the inlet air temperature sensor signal is higher than 4.75V for more than 500 milliseconds.
Fault will disappear within 5 minutes of driving.
Downgrade Modes Activated:
Symptoms: Hesitation, Engine Cutting Out
Suspect Areas:
Description:
Description:
I would ignore this one for the moment - very common in most HDi engines - it just means the glow plug relay is supplied, but the glow plugs themselves are not.
This will likely mean you need one or more glow plugs.
- Deactivation of the coherence faults of the flowmeter
- Deactivation of the airflow faults above the minimum threshold
- Change to "easy move" torque invalid (Automatic handbrake)
Suspect Areas:
- Air temperature sensor on the flowmeter
- Electrical Harness
- Connector
- Engine Management ECU
Description:
- A fuel high pressure regulation fault has already been returned
- For an engine speed below 800 rpm: The difference between the measured rail pressure and the reference value of the fuel flow regulator is 350 bars for 900 milliseconds
- For an engine speed above 800 rpm: The difference between the measured rail pressure and the reference value of the fuel flow regulator is 200 bars for 900 milliseconds
- Engine stopped
- Irreversible cutting of the cruise control
- Deactivation of the automatic mode of the electrically controlled parking brake
- Deactivation of the speed limiter
- Engine hesitating, cutting out
- Diesel fuel consumption a bit higher
- Fluid leak/smells (diesel fuel, oil, etc.)
- Lack of power
- Starting problem
- Engine stopped
- Engine ECU (Software not up to date)
- Poor fuel or polluted fuel (petrol, deposit, etc.)
- Problem on the fuel low or high-speed circuit (hose, tank, diesel fuel filter, etc.)
- Fuel injectors
- Engine fuse box
- Electrical harness
- Fuel high pressure sensor
Description:
- For an engine speed below 800 rpm: The difference between the rail pressure measured and the rail pressure setting is 350 bars for 1200 ms.
- For an engine speed above 800 rpm: The difference between the rail pressure measured and the rail pressure setting is 200 bars for 1200 ms.
- Cut in the exhaust heat recovery function
- Cutting off of the cruise control function
- Deactivation of automatic mode for the electronic parking brake
- The ECU limits the fuel flow
- The activation of the regeneration of the particle emission filter
- Jerking/stalling
- Lack of power
- Starting problem
- Fuel injectors
- Engine fuse box
- Connectors
- High pressure fuel pump(Lack of pressure)
- Fuel pressure regulator (Lack of pressure)
- Fuel pressure sensor
Louisking1
GiveMeABreak wrote: 13 Nov 2019, 15:12 Ok, here we go...
Downgrade Modes Activated:Engine Management Light will be triggered.
Suspect Areas:Fault P0093: High pressure fuel regulation: The fuel flow regulator opens less than the reference value.
- Connector
Description:Downgrade Modes:
Symptoms:
- Engine stopped
Suspect Areas:
- Lack of power
- Starting problem
- Engine stopped
Fault P0087:High pressure fuel regulation: The measured rail pressure is too low in relation to the set point.
- Fuel injectors
- Engine fuse box
Symptoms:
Suspect Areas:
- Jerking/stalling
- Lack of power
- Starting problem
Fault P1351:
- Fuel injectors
- Engine fuse box
- Connectors
Still having same problem anyplace or part in engine that I should look at first to fix problem
