C5 X7 front bumper removal?
jgra1
(Donor 2021)
x 37
Re: C5 X7 front bumper removal?
Unread post by jgra1 »
dont worry Marc ;)
this suggests it is possible withouth removing bumper
http://www.citroen-owners-club.co.uk/ci ... ion/page-2
jgra1
(Donor 2021)
x 37
update :
changing both DRL bulbs is (quite) easy .. I stuck LED's in, which have worked fine all day..
UK Offside is harder due to screen wash bottle.. it took about 30 mins of faffing.. other side took about 10 mins.
these are the ones I bought.. I didn't spend long choosing them :)
https://www.ebay.co.uk/itm/HP24W-G4-18- ... 2749.l2649
Xantippa
x 29
Unread post by Xantippa »
Finally headlights changed from pre-facelift xenon to facelift xenon with led-drl. One headlight had broken height corrector, changed it from old headlight. Also my other "new" headlight came without ballast, got one from old headlight. Headlight repair kit for broken brackets is super handy. Everything works 100%.
x 6957
Great news - so that was the issue you probably had with the old unit then.
Xantippa
x 29
My old headlights worked just fine apart from low beam light on the dash blinking occasionally (something wrong with height corrector??). And one drl-bulb was broken again.
But headlight wiring loom seems to be same on pre-facelift and facelift cars. Also height correctors and ballasts are same.
x 6957
Thanks for the update Marko
