Blocked DPF ?
- My Cars: Fiat scudo van 1.6hdi
Bmw 330d
Rover streetwise rally car
1969 Fiat 500f
Formula27 Fiat TC
Land Rover defender
Blocked DPF ?
Could a blocked DPF cause sudden breakdown and throw up EGR codes ?
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Blocked DPF ?
These are separate issues.
A dpf may be blocked for several reasons - physically blocked because it is end of life due to unburnt Cerine from the additive over the years - this stuff never burns so needs cleaning out or the DPF replacing.
It can also become blocked because regeneration isn't functioning and therefore the soot is not being burnt off. You'll need to fond why it's not regenerating (fault codes will provide all these pointers).
It can be because one or more of the pressure sensors are faulty.
The EGR is separate and can become clogged or inoperative due to an electrical or vacuum issue depending on type of system fitted.
A blocked DPF will throw a warning on the dash (risk of particle filter clogging) or similar. That is the time to investigate, but if ignored then inevitably the vehicle will become inoperable due to the blockage. Again, I can't help as this is a SCUDO and you'll need to get the faults diagnosed with appropriate diagnostic for this vehicle I suspect for a better diagnosis.
Bmw 330d
1969 Fiat 500f
Formula27 Fiat TC
Land Rover defender
Re: Blocked DPF ?
Once again thank you Marc not even sure it has a dpf. Tbh but clutching at straws.
Just spent an hour trundling up and down the road turning off then restarting numerous times. No faults generating on my "launch" reader. Then sat in the drive testing EGR readings. Then sat watching readings with foot hard down reving at 2500. Egr 0% but valve reading 0.1% actual, then the engine note became more strained with some knock and actual Egr was creeping up over1% open . Then battery on tablet died ..... new (cheap) EGR fitted.
Bmw 330d
1969 Fiat 500f
Formula27 Fiat TC
Land Rover defender
Re: Blocked DPF ?
Code just read as P0402 gas recycle to exhaust
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Blocked DPF ?
Generally speaking and on the Bosch Injection System, P0402 relates to Air System Fault - measured quantity of air is lower than the setting.
Specifically, that means there is a positive gap of 10 seconds between the theoretical and calculated air flow where engine speed is between 750 and 2750 RPM.
The fault code will disappear when the car is driven for 5 minutes remaining below engine speed of 3000 RPM.
Whilst this fault is active, the following downgrade modes are in effect:
- Deactivation of diagnosis of coherence on the flowmeter
- Cutting of the EGR butterfly (turbo air cooler), EGR valve and bypass butterfly (inlet air heater) in all operating modes
- Cutting of the "exhaust heat recovery" function
- Limitation of engine torque
- Cutting of cruise control
- Exhaust gas recycling valve
- Air leak between the air flow sensor and the compressor
- Obstacle hindering the passage of the air
- Air flow sensor information incorrect
- Vacuum problem
- Variable geometry of the turbocharger jammed in the "minimum turbo" position
- Principal air meter
- Air flow meter
- turbocharger
- Variable geometry of the turbo + vacuum circuit
- Turbocharging pressure sensor
- Clogged air filter
Bmw 330d
1969 Fiat 500f
Formula27 Fiat TC
Land Rover defender
Re: Blocked DPF ?
Thanks Marc
Food for thought
Food for thought
Bmw 330d
1969 Fiat 500f
Formula27 Fiat TC
Land Rover defender
Re: Blocked DPF ?
On inspection today it seems the turbo has now seized , it was spinning last week I'm sure , but I'd say it's at the root of most of my problems now
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Blocked DPF ?
Sorry to hear that - could be down to oil starvation. Some of the 1.6 Ford PSA engines suffer from blocked oil channels that can carbonise and cause blockages. Very frequent oil changes are recommended to keep the oil clean and remove deposits on these.
