1.6 Hdi broke down now running but no power
- My Cars: Fiat scudo van 1.6hdi
Bmw 330d
Rover streetwise rally car
1969 Fiat 500f
Formula27 Fiat TC
Land Rover defender
Re: 1.6 Hdi broke down now running but no power
Any further comments ?
The unit that is circuled red map sensor I would bet my bottom dollar is your problem this is your boost pressure and air intake a 4 terminal plug
must have 2 x 5v feeds replace this sensor and if it does work post back Regards mickeybo
Bmw 330d
1969 Fiat 500f
Formula27 Fiat TC
Land Rover defender
Tried a new MAP sensor today , no better sadly. Running out of money and options . But Thanks
Bmw 330d
1969 Fiat 500f
Formula27 Fiat TC
Land Rover defender
Did try removing the vacuum pipe from the turbo “variator” got the liveliest drive so far so at least it proves the turbo is working but something is stopping normal operation.
Hello, I have exactly the same problem, I have checked everything but still the same problem. (FIAT SCUDO 1.6 HDI)
Have you solved your problem? Thanks
