Apparently I need a new timing belt tensioner. Now I don't know which one I need, though I suspect it is the one with springs as that one seems likely to be the one to stop tensioning.
Where (besides the useless Citroen garages) could I get these from. The engine is the 2.0 16v 150 hp version. Is the timing belt and assembly the same as that of the 1.8 16v?
Thanx
Timing belt tensioners
- x 1052
roscopervis
- x 1463
Are you talking about the auxiliiary drive belt, rather than the timing belt - the one that drives the alternator, HP pump and compressor?
If so, the spring tensioner is only availble from Citroen (for a TD anyway - I helped a mate change one) and it's a 3+ hour job to change it as you have to take the HP pump and alternator off.
Richard
Richard
roscopervis
- x 1052
- x 1052
roscopervis
