Can anyone help please ?
I’m getting 2 fault codes relating to the additive system on my Picasso 1.6 hdi 2010. P1434 and P1435. Could anyone shed any light on a solution to this problem please ? It would appear to be an electrical fault or pump failure, but how do I find out which one ?
Thank you.
Additive not working
- x 6955
Re: Additive not working
Are these related to your other post here:
viewtopic.php?p=613374#p613374
We did ask for the VIN in that post and got no reply - and will need it if you want the fault codes explained as they relate to this specific engine ECU.
Benscab123
- x 3
Sorry I didn’t see that reply
My vin is - VF7**************[VIN obfuscated, can be read by forum staff]
- x 6955
Ok, so those faults both point to the additive pump itself with the additive pump seeming to be getting too hot.
| Fault code | P1434 |
| After sales description of the fault code | Particle filter additive system: Excessive temperature or open circuit |
| Description of the diagnostics | Excessive temperature on the power stage of the additive pump |
| Conditions of activation of the diagnostics | Consult the associated contexts for the Pcode forwarding conditions |
| Conditions of disappearance of the fault | Ignition on |
| Down-grade modes if fault present |
| Switching on of the warning lamp and/or warning message | - |
| Main customer complaints likely | - |
| Suspect areas | Additive pump |
| Fault code | P1435 |
| After sales description of the fault code | Additive system: Additive system fault |
| Description of the diagnostics | Diesel fuel additive ECU (ADDGO): Problem of communication on the CAN |
Benscab123
- x 3
Thank you, I’ll order a new pump.
- x 1485
service.citroen wrote:
Benscab123
- x 3
Yeah I’ll have a look for a good used one. Where can I find info on priming and configuration ?
