I think i have to buy a newer one. One guy mentioned that he had the same screen issue during usb music ...
RD45 questions + Microphone installation C5 X7 + Amplifier installation
neszim81
Re: RD45 questions + Microphone installation C5 X7 + Amplifier installation
Few moths ago you have checked the type of my current screen. Can you pls tell me is that 12 pin or 6 pin?
- x 6955
Yes that is the mic pin for the RD4
neszim81
First of all, merry christmas!
I just want to inform you that after HU replacement i have replaced the display too. Now everything is working fine. Yeeeaaaah! I love this "system".
Thank you guys for the help and hints!
Happy new year!
Happy new year!
Danilos
Hi friends, could someone please write me or show me the pictures or video, how to easily remove that plastic where is the place for the microphone?
tobias_84
Nice work!
I'm doing some new speaker replacement my self and found this thread. Do you have a wiring diagram for the speaker wires? They seems to change colour between the door connector and the head unit. The factory cables is kinda tiny....
Regards
Tobias
Regards
Tobias
toralux
Hi, neszim81. I have also replaced RD4 with RD45 and also ordered new display from AliExpress. I have DiagBox and PP2000 from AliExpress as well.neszim81 wrote: 29 Dec 2018, 17:05 I just want to inform you that after HU replacement i have replaced the display too. Now everything is working fine. Yeeeaaaah! I love this "system".
I have some questions:
What did you do with the old external bluetooth module for RD4? (Now I find both external bluetooth for RD4 and the internal bluetooth for RD45, but I'm not able to pair or use any of them).
Did you manage to connect the microphone on RD45? To what pins?
- x 6955
If you had the factory nomad (hands free unit) installed, you need to disable it in PP2000 / Diagbox or it will conflict. Do this when configuring the RD45 unit. And if you haven't CIN coded or configured the RD45 correctly then it won't work either.
As for the microphone question - it's all in this thread...
viewtopic.php?t=58078&start=180#p593468
- x 1438
Although you probably need to configure (in the BSI) the nomad module itself to be disabled (maybe best to unplug it), you need to leave it configured to present somewhere (perhaps in the display ECU) for the RD45 bluetooth to work. Sorry about vagueness, I am working from memory of installing an RD45 in a car that did not have a nomad.
Slobo2712
Is it possible to update MFD sw to be comaptiable with RD45,because i cant connect with phone bluetooth?It is JCE EMF- C- CEM1 with SW v51.6 and HW v1503?Tnx in advance.
- x 1438
I don't think that there is any way for update the software on the EMF-C, you need to find one from a later car with a compatible software version.
Slobo2712
Tnx for answer,thats what i thought..But is there anyway to pair phone with radio somehow on blind,my english is not best so i cant explaine but i saw on youtube video when radio is found with phones bluetooth there are numbers on screen(on my screen there is just confirmation after that nothing).I have tried on blind type on phone 0000-pair-confirm yes on radio screen-ok ok ok ok-arrow down and left..But i didnt succided..xantia_v6 wrote: 21 Oct 2019, 07:40 I don't think that there is any way for update the software on the EMF-C, you need to find one from a later car with a compatible software version.
- x 6955
The software version may be able to be updated, but only from PSA servers via a dealer.
The BSI doesn’t need configuring, but the ECU on the EMF-C does need to be configured with the correct options or it will not display Bluetooth functions. You need to do this with Diagbox or Lexia software once you have a suitable EMF-C display.
Slobo2712
I have diagbox and enabled bluetooth kit,it showing telephone options but as you said they are not correct..
- x 6955
Can you post your VIN and attach a couple of screenshots of the screen so I can see which options you have selected and then I can compare these to make sure you have the correct options selected.
Slobo2712
Reason: Uploaded Images for permanent display
