suspension ecu
x 6955
Re: suspension ecu
Only if there is an integrated BHI present, whether metallic or hydropneumatic suspension and finally an area to configure the damping only for V6 engines.
KennyW
x 163
Re: suspension ecu
Unread post by KennyW »
Is it worth looking in the BSI configuration pages to see the ECU's listed.
C3 1.4 petrol (SWMBO)
x 6955
Re: suspension ecu
They won’t be listed Kenny. Only the options I mentioned as part of the BSI configuration. These settings will not have changed on their own unless manually changed previously. Secondly, if there was any issue there with the wrong setting either the suspension wouldn’t be working or you would have a second suspension ECU showing under the global test but with another communication error.
I would do a BSI reset first paying attention to the timings and I would check the battery condition too while at it Kenny
BSI Reset / Battery Disconnect / Reconnect Procedure
But check out the post after this one first: ?
x 6955
Re: suspension ecu
One other thing - the diagnostic pin associated with the suspension diagnostic information going to the OBD connector is Pin 12. The same wire on the 32 pin Black wiring plug on the BHI is Pin E2. So might be worth checking the connector at the ECU end and that the pin on the diagnostic port / your OBD connector is making contact.
KennyW
x 163
Re: suspension ecu
Thanks Marc
Fortunately I have the wiring diagrams and much fun with Citroen wiring in the past!!!!!!!!!!
Kenny
x 6955
Re: suspension ecu
Let us know how it goes, it there's no continuity, there may be a pin issue or a break somewhere.
KennyW
x 163
Re: suspension ecu
Well done BSI reset no change. Will start checking continuity at diagnostic socket and work my way through.
Will also check at sus ecu for a voltage.
Wish me luck knowing citroen electrics.
Kenny
x 6955
Re: suspension ecu
Likely you’ll sneeze and it will be back up and running!
x 2941
Re: suspension ecu
GiveMeABreak wrote: 20 Oct 2019, 20:12 Likely you’ll sneeze and it will be back up and running!
I wish that were true of mine, sorted the fuel problem, took the car on a 140 mile round trip on Friday, a mix of local and fast A417, All good apart from the torrential rain on the homeward journey.
Went out yesterday to take an old friend to lunch and the suspension is rock hard, pressing the up and down switch seems to work and show OK on the screen but it ain't, cant get it to normal ride position.
I'm guessing either the spilled diesel from the fuel problem or water from the rainstorm has got into the front height corrector (looking at it this morning it's up high on the front), so back under the damned thing when the rain stops. :evil:
KennyW
x 163
Re: suspension ecu
Broken dog bone possibly.
x 2941
Re: suspension ecu
Not on this one Kenny, it has a metal version of the old plastic dog bone, they occasionally disconnect (it hasn't) but they don't break.
KennyW
x 163
Re: suspension ecu
The front one is pain to get near protected by the subframe. I must admit I did spray mine liberally with penetrating spray then once moving graphite spray with the frame off the car.
Kenny
KennyW
x 163
Re: suspension ecu
Marc,
Do you still have the photo of the ODB 16 pin plug ?
It seems the photo's you posted have vanished or was I looking at another topic !!!!!!!!
Kenny
x 2941
Re: suspension ecu
Sorted! Green crud on the connector pins.
KennyW
x 163
Re: suspension ecu
Excellent at least it was simples for French electrics.
Kenny
