Does the bipper heat controls have bulbs
Just noticed mines unlit
If so
How do you remove unit to get at the bulbs
Bipper heater controls bulbs
Re: Bipper heater controls bulbs
Anyone?
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 2993
Give it a bit of time, there will be somebody who has replaced them (or knows how to replace them) replying at some time. I cannot help you, as I have no experience of the Bipper.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5646
There'll probably be a bulb holder at the back of the unit, necessitating part of the central dash trim removal to get at the mounting screws of the heater unit.
Pop up your VIN and I’ll take a look.
Vin VF3**************[VIN obfuscated, can be read by forum staff]
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, so this is the unit you have - although there are no obvious indications of a bulb from the pictures below - these do have some form of lighting - so you may need to examine or unclip the black cover to see if they are inside.
Here is part of the fascia removal procedure to get the panel off - but be careful, as there are manual cables attached to the dials that operate the heater controls.
So good luck with finding the bulbs - and if you do, an update would be great to show the type they are.
Unclip the dashboard vents. Unclip the plate (1). Disconnect the connector ( as "a"). Remove ye plate (1). | Unclip the centre panel control pad (4). Disconnect the connector ( as "b"). Remove:
Remove the bolts (5). | Unclip - Remove the fascia panel upper trim (6). Remove bolts (7). |
Unclip the gear lever gaiter (9). Remove the gear lever (8) base trim. | Unclip - Remove the fascia left-hand lower trim (10) ( as "c"). Remove the bolts (11). N.B. : Symmetrical operations. |
Remove:
| Remove the bolts (15). Detach the air conditioning panel (14). |
Thnx for that kind sir
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I never bothered in the end
Lot of hard work.
Spent 15 mins then sacked it
Lot of hard work.
