The van only seems to have one sensor on the drivers side as far as I can tell, there don't appear to be any wires under the passenger seat.
There is what I assume is a pressure type sensor on the drivers side, it is a two wire switch that I linked out but it is still the same.
Can anyone offer any help or suggestions as to what the issue might be?
Nemo van seat belt light randomly coming on
OnlineHell Razor5543
- x 3299
Re: Nemo van seat belt light randomly coming on
I would assume a simple switch in the seat belt latch, as the system need to 'know' if the belt is latched or not.
blake7
- x 3
I was looking at this pic from evilbay and this is the plug I tested. Looking at it, although there is only one plug I'm guessing there must be an inline switch in the seat belt stalk that is made from the buckle. A switch as you said.
