Peugeot 207 sensor/control identification
Post Reply
LittleOldSuzi
My Cars: Peugeot 207 1.6 HDi
x 6
Post by LittleOldSuzi »
The 207 is trying my patience a little bit now but it will not win. I need to identify the sensor/control that is circled red.
I can hear a tiny boost leak and the throttle body (if that is what you call it on these) and the bonnet have smears of oil on, I cleaned them down and a week later they are oily again. The sensor I have circles appears to be the culprit and oil is even inside the plug socket itself after it was cleaned out. I am guessing the boost pressure is getting passed the seals but what is it and can I buy it separately or do I need the entire assembly?
Thanks as always...
https://srv-file7.gofile.io/download/38 ... sensor.png
Lexia Available: Yes
My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ)
x 833
Re: Peugeot 207 sensor/control identification
Post by xantia_v6 »
The server where you uploaded your image file wont allow general access, so no-one else can see it.
I suggest that you upload the image to this server using the attachment tab at the bottom of the post edit window.
LittleOldSuzi
x 6
Hopefully that should be OK now. Cheers for the heads up.
Muscleriot
My Cars: 207 1.4 16V 88 hp petrol
Post by Muscleriot »
You will need to supply the vin to look up the part for your car
Post Reply
