The 207 is trying my patience a little bit now but it will not win. I need to identify the sensor/control that is circled red.
I can hear a tiny boost leak and the throttle body (if that is what you call it on these) and the bonnet have smears of oil on, I cleaned them down and a week later they are oily again. The sensor I have circles appears to be the culprit and oil is even inside the plug socket itself after it was cleaned out. I am guessing the boost pressure is getting passed the seals but what is it and can I buy it separately or do I need the entire assembly?
Thanks as always...
https://srv-file7.gofile.io/download/38 ... sensor.png
Peugeot 207 sensor/control identification
LittleOldSuzi
- x 6
- x 1438
Re: Peugeot 207 sensor/control identification
The server where you uploaded your image file wont allow general access, so no-one else can see it.
I suggest that you upload the image to this server using the attachment tab at the bottom of the post edit window.
LittleOldSuzi
- x 6
Hopefully that should be OK now. Cheers for the heads up.
Muscleriot
You will need to supply the vin to look up the part for your car
