Where have all the xantia posts gone?
- x 1460
Re: Where have all the xantia posts gone?
Do you know if it is the ram itself leaking, or a spit pipe (due to the ram coming loose on its mounts)?
The Xantia V6 rack is unique and not used on any other Xantia, so (particularly in RHD) is fairly rare, but you might get lucky.
HunterSteel
- x 3
xantia_v6 wrote: 09 Sep 2019, 11:23 Do you know if it is the ram itself leaking, or a spit pipe (due to the ram coming loose on its mounts)?
It looks like its a seal on one of the pipes that feeds that ram. My little brother was the one who took this picture. It's on the Driver's side of the car.
~Hunter
Citroens I owned or did own:
Citroen Xantia 1.9TD
Citroen Xantia V6 Exclusive Phase II
Citroen BX 16v
Citroen CX 25 Turbo II
Citroen CX 2400 Prestige
Citroen GS Club Break
Citroen GS Club
Citroen BX 16v
Citroen GS Club
Michel
Saw loads in France a couple of weeks ago out around Verdon Gorge and Regusse!
- x 1460
In that case, it is unlikely to be the rack itself, and you really need to see exactly where the LHM is escaping.HunterSteel wrote: 09 Sep 2019, 12:48xantia_v6 wrote: 09 Sep 2019, 11:23 Do you know if it is the ram itself leaking, or a spit pipe (due to the ram coming loose on its mounts)?
~Hunter
- x 1746
Does look like that union to the left of the shaft, that has been washed clean by the leaking fluid.
You might be lucky and just be able to renew the rubber sleeve in the joint.
Worth a try.
Worryingly rusty under there, and in real need of some protective wax.
Worth a try.
HunterSteel
- x 3
Luckily for us it really is only a rubber seal that got old.white exec wrote: 09 Sep 2019, 17:39 Does look like that union to the left of the shaft, that has been washed clean by the leaking fluid.
Worth a try.
Also, that's not rust. That's dust and soot that collected under there from when my Dad used the car in Zambia to drive him to work at the mine. (He was the Project Manager and the office was always through dirt roads so it picked up this dust and soot.)
~Hunter
Citroen BX 16v
Citroen GS Club
Citroen BX 16v
Citroen GS Club
- x 1460
It might be a steel cone joint, not a rubber seal, I am not sure, but I have a feeling...
van ordinaire
- (Donor 2017)
- x 400
Well my Xantia's still serving well as a family hack - & I keep getting told how impressed everyone who's ridden in it is with how comfortable it is. I think I've only driven once since getting back from Maastricht in January. Then again, I've not had to do much except an oil & filter change - although I suspect another is due. Must do something with the brakes too as they were an advisory on last MoT, so it may figure more here than it has thus far.
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
jauv
- x 12
Joined the forum to read up on tomorrow's plan - going to check out a 97 Xantia which looks to be in decent shape with ~135 000km in odometer. Though it has sat in storage for 10 years until recently, so I'm not expecting much. Hopefully it's as good as it seems, would certainly lead to more Xantia content.
daviemck2006
- x 485
My Xantia is out of MOT, been sitting at the side of the house for more than a year. I am unable to now try to fix it and needs too much things done to make it economical to sort. Anyone who would want to save her, come get her.her
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
Skull
- (Donor 2026)
- x 381
Davie I was at Dornoch a few weeks ago and would have taken a runner off you
Gary
Gary
admiral51
- (Donor 2026)
- x 391
oh no another temptation
Skull
- (Donor 2026)
- x 381
They're everywhere at the moment
Gary
Gary
jauv
- x 12
What have I donejauv wrote: 11 Sep 2019, 15:41 Joined the forum to read up on tomorrow's plan - going to check out a 97 Xantia which looks to be in decent shape with ~135 000km in odometer. Though it has sat in storage for 10 years until recently, so I'm not expecting much. Hopefully it's as good as it seems, would certainly lead to more Xantia content.![]()
- x 1746
